Russ84na Posted November 5, 2007 Share Posted November 5, 2007 I have heard that you can bore a VG30 out to VG33. Has anyone actually done this? Not interested in should be's or some guy did it. Thanks. Quote Link to comment Share on other sites More sharing options...
Russ84na Posted November 7, 2007 Author Share Posted November 7, 2007 With the number of lookers and no responses, I am assuming that boring a VG30 to a VG33 is bull. How much can you safely bore out a VG30? So far I am seeing people going to 87.5mm to use Z32 pistons. Anyone gone farther than this? Thanks. Quote Link to comment Share on other sites More sharing options...
nismopu Posted November 7, 2007 Share Posted November 7, 2007 I have never bored one out, ever but I bet the guys over at z31performance.com or vgpowered.com could help you out. peace. Quote Link to comment Share on other sites More sharing options...
Pete84 Posted November 8, 2007 Share Posted November 8, 2007 The VG33 is 91.5mmx83mm and came in a number of Nissan's. http://en.wikipedia.org/wiki/Nissan_VG_engine#VG33E Quote Link to comment Share on other sites More sharing options...
nismopu Posted November 8, 2007 Share Posted November 8, 2007 VG33 is a different block than the 30 and far as I know you cant just bore it out to 91mm but I have no experience. peace. Quote Link to comment Share on other sites More sharing options...
SATAN Posted December 9, 2007 Share Posted December 9, 2007 Just so you guys know... You are not supposed to bore out a vg30 (87mm) to the 3.3 liter diameter of 91.5mm The water passages are moved outward from the bore on the VG33 blocks. This is to give the block more meat between the cylinder walls and the water passages. Now, is it possible? probably. Will it hold a ton of power? Probably not. Quote Link to comment Share on other sites More sharing options...
Guest asheweb Posted January 27, 2008 Share Posted January 27, 2008 The 3.3 block just has a longer nose, hence the end of the crank is a little longer which would make the crank pulley out of line with the VG30's accessories. It is possible to (a)machine the nose down so that a VG30DETT (or any VG30) crank can be used, or (b)to machine down the VG33 nose slightly and bore up the VG30 pulley slightly so you gain the advantages of a bigger nose. Either would allow you to use all of the accessories from your VG30. My math might be wrong but, I'm pretty sure you would only have to remove 2.25mm from the cylinder walls to go from 3.0L (87mm) to 3.3L (91.5mm). I wouldn't think the water passages would be that close... but, i haven't had the head off of a VG30 or VG33 yet. I am, however, planning to build a VG hybrid engine for my 93 SE-V6 4WD truck using the VG33 block. So, when i actually find one, I will be able to tell you for certain the differences between them. You could also go to NissanForums.com and ask Mike (MorePower2)... he seems to know allot about the VG engines. I hope this helps some. Quote Link to comment Share on other sites More sharing options...
Racinjitter Posted January 28, 2008 Share Posted January 28, 2008 How much can you safely bore out a VG30? Thanks. To be certain, you will have to X-ray your block to see how far you could safely bore. I am pretty sure that every engine will be slightly different from each other but by only a few ten thousandths. Quote Link to comment Share on other sites More sharing options...
Guest Sharkracer Posted January 29, 2008 Share Posted January 29, 2008 I have 88mm wiseco's in my block making it a 3.1L. It looked like there's plenty of space between the cylinders, but like mentioned, there's spaces in there you can't see. Quote Link to comment Share on other sites More sharing options...
SATAN Posted March 5, 2008 Share Posted March 5, 2008 There is a reason Nissan made two different blocks for the 3.0 and the 3.3. The water passages are moved outward for the additional .3 liters. This is not a guess, it is a fact. Can you take the 3.0 out to a 3.3? Probably. Will it be very strong? Probably not. Quote Link to comment Share on other sites More sharing options...
dscott@red3 Posted March 6, 2008 Share Posted March 6, 2008 Why not just start out with a VG33. I have plans on this for my 510. Quote Link to comment Share on other sites More sharing options...
