Rear coilover clearance question
Hey Jason, My rear coilover springs are the typical 2.5 inside diameter. The outside diamater of this spring is 3.45. The lower coilover seat itself measures 3.50. I do not know the outside diameter of oem type springs. The oem spring seat on the strut tube itself I would imagine dictate a slightly larger diameter.
So maybe like this??... OEM spring seat diameter and subtract the 3.50. Then divide that number by 2 should get you closer to the extra tire clearnace. Hope this helps.
Are you planning to flare the car? If not, you'll possibly be able to squeeze a 265 series tire under the fender, with it rolled, but a 275 series won'd go. I tried this with my setup and was able to get 1/16th inch clearance between my 9.5inch wheel/275 series tire and the coilover setup with the 2.5inch diameter coil perch set above the tire. Now that I have adjustable control arms and camber plates, I could probably have moved the tire in a hair more to make a 275 series tire work, but didn't try it, and now I've got flares on the car...
mike
