Sideways Posted November 26, 2007 Share Posted November 26, 2007 Im really lost on this one- What did you do about your brake lines? Searching Ive found people with the s12+8 vented setups that can just use the stock caliper hardline (the little S bent piece right on the caliper), mount it into the s12+8 caliper, and a regular 240z line will obviously bolt right up to that. Is this method also true for the s12w setups? I could always buy one of the swap-specific ss-braided lines, but ive already got MSA 240z brake lines, and id rather not drop 70 bucks on just the lines if i can avoid it. Anyone have links to good writeups with pictures showing what was done? Or anyone have any good suesstions on what I can do? Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted November 26, 2007 Share Posted November 26, 2007 I re-used my 240Z Goodridge S/S Braided lines for the OEM caliper and OEM bridge pipe. I just repositioned it so it won't interfere with the steering. Don't forget to trim the backing plate too. Good Luck! Quote Link to comment Share on other sites More sharing options...
Sideways Posted November 26, 2007 Author Share Posted November 26, 2007 Hmm your pictures show s12+8s though? I need to know about the s12-w. Unless that was just a generic picture and thats what you did with your s12ws? Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted November 26, 2007 Share Posted November 26, 2007 I have the vented set up and managed to reuse the hardline. Had to bend it carefully, maybe a bit more than I was comfortable with, but it works. Like you I didn't want to throw away my MSA SS lines. Someday I might go back and make a new hard line. Quote Link to comment Share on other sites More sharing options...
Sideways Posted December 4, 2007 Author Share Posted December 4, 2007 Finally got around to doing the conversion, just want to let anyone know who may be looking for the information- Yes the S-Hardline does indeed bolt right into the S12w, and required very little bending at all to make work properly. Quote Link to comment Share on other sites More sharing options...
