seat/door panel ?
CantZme
It depends on the year of your 280Z The early (75-76) 208Z should fit the doors but they changed the doors on the 77-78 to a diferent setup. Usually the only differences are the push/pull lock in the upper corner are in different locations as are some of the door handle locations. As for the seats any seat from 1970-1978 should be a direct bolt in. Worst case you would have to swap the seat tracks out. Hope this helps. Rick
