What wheel is this...
They are SSR Longchamp XR4's. I have a set on my Z...15x8 -14 in the rear and 15x7.5 -7 in the front. They just barely fit under stock fenders.
I don't have pics of them on my car but here they are up close...
You can find them used but you'll need to look for awhile. I see them pop up from time to time on club4ag for sale (wheel) forums.
That is a good price... just not the right size. Great find though. Thanks and I'll be on the lookout.
oh, and regulatoi, if you get a chance to take a pic of those wheels on your car, post them, I'm sure everyone including me would love to see it.
Yeah, the price for the Longchamps is about right. You can find them for a lot cheaper if it's the more common offsets...like 15x7 with positive offset. You start going wider with negative offsets, the price almost doubles. You rarely see any Longchamps wider than 15x8 in the US so there is a high demand for the wider ones.
From what I've seen, Longchamp Xr4's only come in 13s, 14s, and 15s with everything from 5.5" wide to 12" with many combination of offsets. They make a 5 spoke version too but I've only seen them in Japan. I know the XR4Z comes in larger sizes like 16s+ but they look a bit different than the standard Xr4.
I'm being stationed in Okinawa next year (Marine Corps) so I'm hoping I'll have time to hit the used wheel shops and ship some wider rims out here....they're a LOT cheaper over there.
Here is a pic of Longchamps on my Z...
http://forums.hybridz.org/showthread.php?t=128575
The tires are Toyo T1R...rear being 215/45/15 and the front 205/50/15.
I purchased them from http://www.edgeracing.com/ which is by far the best prices I've seen.
The suspension is ground control coilovers (225/250lb) and Tokico Illumina adjustables. My strut tubes are about an 1.5" shorter and the Tokico's are shorter stroke... (240Z fronts go in rear and you buy Mr2's for the front)... read here..
http://forums.hybridz.org/showthread.php?t=100536
http://forums.hybridz.org/showthread.php?t=103860
You have to run sectioned coilovers to go as low as I am because you won't have any travel on stock struts. You can't really tell from the pics but my car is pretty low. If you don't want to section your struts and just go lowering spring/aftermarket strut, then just buy bigger profile tires.
