zane9000 Posted January 14, 2008 Share Posted January 14, 2008 Is there anyway to convert O-Ring injectors to barb injectors? It seems to me that if you just smooth off the sides of the inlet you should be able to clamp a hose on there? I have kind of a unique set up that I am trying to make work and I don't really want a fuel rail, but the injectors I want to use are O-Ring. Any Suggestions? Quote Link to comment Share on other sites More sharing options...
Xander Posted January 14, 2008 Share Posted January 14, 2008 what you suggest is possible. I ran my 37 lbs injectors that way. I cut off the plastic of the back end of the injectors to expose the metal underneath. Then you can just slide a hose over the end. Use good hose clamps. In the end I did convert to a palnet fuelrail because one of the injectors started leaking between the plastic and metal inner tube. Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted January 14, 2008 Share Posted January 14, 2008 Depends on the o-ring injector. Some people use them, and what they do is just slip the hose over where the o-ring normally goes. Depending on the injector, that might require cutting off some of the plastic around that area. Make sure you use good quality fuel injection clamps. Mario Quote Link to comment Share on other sites More sharing options...
Clifton Posted January 14, 2008 Share Posted January 14, 2008 I have with DSM 450cc injectors. I trimmed a little of the base plastic off first to give the hose more room. Quote Link to comment Share on other sites More sharing options...
zane9000 Posted January 14, 2008 Author Share Posted January 14, 2008 Great, thanks for the info guys! Quote Link to comment Share on other sites More sharing options...
