T04 overhaul manual
dapiper
Anyone have a source for the TO4 repair manual? I am rebuilding a 10 year old Turbonetics H3. I have progressed to the bearing housing internals. It was doing fine, but a little sloppy on radial end play. I have the rebuild kit.
OBTW, can you rebuild with out separating bearing housing from turbine housing, since they are corroded together?
I would soak it good with WD40 or similar and get it hot and tap it with a heavy hammer. Be careful not to damage the wheel though. If you do bend a blade a little you can bend them back. As far as balancing. The compressor wheel and turbine wheel are balanced individually. I know Turbonetics balances them as an assembly when they assemble them. I have mixed there assembly balanced parts on one turbo and didn't have a problem. I have done it alot on individually balanced turbos too. I know of two local turbo rebuild shops that don't even have a balancer.
Thanks guys. Hate to spend $400 for rebuild, but cannot separate turbine housing. Thats 1/3 cost of GT35R.
Never used to bother with balance on old Rajay rebuilds.
Will a propane torch get hot enough?
It's better than nothing, I used acetylene and had to beat the piss out of it with a 3lb hammer. Just make sure it doesn't come off crooked and damage the wheel.
My personal favorite penetrating oils are PB Blaster and Kroil.
