280zjoel Posted February 4, 2008 Share Posted February 4, 2008 ok, so im doing an sr20det in my 75 280z and i'm doing a similar setup as Alex's top mount 240z from vildini motorsports. (mines a little more mickey mouse thought:weird:) I had an ubber-noob moment and decided to run a q45 throttlebody instead of the stock sr throttlebody. that being said there is bout 1 to 1.5 inch gap between the throttlebody and the intercooler outlet, is it ok to just use a 3''-3.5'' transition hose to connect the intercooler to the throttlebody? Does anyone think there will be any issues with engine movement causing the hose to tear under load? Quote Link to comment Share on other sites More sharing options...
mattyice Posted February 4, 2008 Share Posted February 4, 2008 i dont see there being much of a problem, silicone couplers are very strong, just make sure you have high quality ones and you will be fine Quote Link to comment Share on other sites More sharing options...
Bankai Dan Posted February 4, 2008 Share Posted February 4, 2008 I agree with Mattyice. On my friend's sr20 swapped awd talon, he is running a transition coupler on 22+ lbs with no problems. Just make sure you buy a quility piece and some good t-bolt clamps. Quote Link to comment Share on other sites More sharing options...
280zjoel Posted February 4, 2008 Author Share Posted February 4, 2008 yup, im using 4 ply intercooler hose which is rated to hold up to 80psi lol wich i wont even get close to heheheh. Quote Link to comment Share on other sites More sharing options...
Bankai Dan Posted February 4, 2008 Share Posted February 4, 2008 lol, that's what you call a good FS. nothing better than a factor of saftey of a few hundred percent. Quote Link to comment Share on other sites More sharing options...
mattyice Posted February 4, 2008 Share Posted February 4, 2008 i usually in that situation would of tried to use a hump coupler for added flexibility but you really cant because of needing a 3"-3.5" reducer Quote Link to comment Share on other sites More sharing options...
280zjoel Posted February 4, 2008 Author Share Posted February 4, 2008 i was looking for a 3'' to 3.5'' hump hose but i couldnt find any, so the transition hose will have to do for now, eventually i move the intercooler forward closer to the core support and do a better v-mount radiator than the one i'm currently going to run Quote Link to comment Share on other sites More sharing options...
panachedk Posted May 13, 2008 Share Posted May 13, 2008 where did you get that ic? Quote Link to comment Share on other sites More sharing options...
Lunar240z Posted May 13, 2008 Share Posted May 13, 2008 I'm doing a v mount with my SR20 setup as well, but I had more space between the enigne and intercooler than that. I used a transition and a hump hose. I would put the IC more forward if you could. On the other hand You could solidly mount the engine... but this isn't a good enough reason to do that. Quote Link to comment Share on other sites More sharing options...
280zjoel Posted May 16, 2008 Author Share Posted May 16, 2008 where did you get that ic? i cant find the exact one i got but here is another one ou can use, just make sure the dimensions will fit your car. http://cgi.ebay.com/ebaymotors/CXRacing-INTERCOOLER-24x11x3-Mazda-RX7-V-Mount-FMIC_W0QQcmdZViewItemQQcategoryZ33742QQihZ013QQitemZ230251862904QQrdZ1QQsspagenameZWDVW Quote Link to comment Share on other sites More sharing options...
VQ240Z Posted June 3, 2008 Share Posted June 3, 2008 There shouldnt be a problem running a coupler to the throttle body.. i did my vmount before alex!! he improved upon my design alittle bit but mine still works great. heres a link to the pics http://www.vildinimotorsport.com/gallery/gavin.html Quote Link to comment Share on other sites More sharing options...
