What should I steal from this 280Z fo rmy 240Z???
Hey guy's,
Found a guy parting out a 280Z (1977), a friend actually.
I get all the parts I want for free.
What should I snag to upgrade my 240Z ????????
My entire suspension (on the 240Z) is off, and I have a money to burn.
I was thinking crossmember, struts, steering rack, what else should I snag???
Thanks all for you input!!!
Pete
I would love you to death if you could snag me the clutch slave cylinder, throwout arm, pressure plate, throw out bearing, and include all bolts from said parts. But that might be too much to ask ;)
I'd grab all the stuff you mentioned, plus the mustache bar and R200 diff (if it's got it), whole engine and tranny to swap in if you're greedy...
front hubs if you want to do a AZC brake upgrade
rear stub axles, the're stronger with a larger spline count, but you'll also need the half shafts with that as well.
turn signal switch if they are good
headlight switch if they are good, these go bad pretty often
ashtray, I dunno just thought I would throw that in
