midnight-z Posted March 13, 2008 Share Posted March 13, 2008 I got my 280Z 3 weeks ago and I replaced the problematic fuseible links I replaced them yesterday The car dosen't run it starts to turn over and stops a second later they looked craped out so I put new ones on Now the gauge reads 8 I got a battery charged so it was above 12v I put the old ones on I tryd to start 4x it went back to 8 all the 4 new wires are the same thickness 2.0 sq mm fusible link dielecric grease on the terminals I think it could be the battery or I caused a short:lol: I disconected the negitave bat-cable then took all 4 links off I put the new ones on with the grease and I put on the negitve cable. All the info I found was about maxi fuse conversions and one about a simalar case 3 days before I exchanged the all tail light bulbs with my 97 integras sylvina bulbs. Could it be the volt regulator or battery ? Quote Link to comment Share on other sites More sharing options...
Lukaniuk Posted March 13, 2008 Share Posted March 13, 2008 Have you tried to start the car with another battery that you know is good? or boosting it with another car? Quote Link to comment Share on other sites More sharing options...
midnight-z Posted March 13, 2008 Author Share Posted March 13, 2008 The terminals were on tight so I pryed them with a screwdriver. I want to take the battery tomarow to have it checked out by better people than autozone Also does the guage thickness of the links matter? I put the original fuse links on nothing happened that same day with a 12+ charged battery I will study the manual agian if volt regulator and if the batery is okay I wil test the alternator. also I forgot to put the glove box light bulb in its socket so it hanged empty and loose for three days. could that do anything? A simalar thing happend with a guy who replaced one link ended up towing to a Z shop then they put a $5 link for $100 and the car run to this day Quote Link to comment Share on other sites More sharing options...
midnight-z Posted March 13, 2008 Author Share Posted March 13, 2008 I went today and I got this info After looking at the Nismo 350Z for 10min Apeatently there is diffrent guages of wires? here is the fuselink part # and the numbers writent are amprage all 4 are diffrent does anyone on here anything about this? My theroy is that they have special wires or magical one dealer has them for $8.00 each but they need the part number nobody has them they are special order. the ones I put on say fusiblelink wires are the same thickness and say 2.0 sq mm fusible link they are made by some Z store from 260 to 280 Z Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted March 13, 2008 Share Posted March 13, 2008 Tips: http://www.atlanticz.ca/zclub/techtips/fusiblelinks/index.html More Tips: http://www.atlanticz.ca/zclub/techtips/electricalconnections/index.html Or buy this: http://cgi.ebay.com/ebaymotors/Datsun-260z-280z-Fusible-Link-Covers-Wires-NEW_W0QQcmdZViewItemQQcategoryZ46101QQihZ011QQitemZ320226676487QQrdZ1QQsspagenameZWDVW Or convert to this: http://www.hammondsplains.com/s30upgrades/maxifuse/index.htm Quote Link to comment Share on other sites More sharing options...
midnight-z Posted March 14, 2008 Author Share Posted March 14, 2008 Hell yeah thats what I'm talking about How come we don't have info like that here? The battery tested good its from 03/07 I tested the bat/alter on third day I got it it got a green light I thought I shorted it or something. the links i installed seem to be above 100amps bigger than 1.25mm2 I wanted to get the maxi upgrade after i get taxrefund I will clean grounds and inspect voltage stablizer. Quote Link to comment Share on other sites More sharing options...
midnight-z Posted March 22, 2008 Author Share Posted March 22, 2008 I got the Z to run I found that a ground was missing thanks to 240ztt Also I sanded the hell out of the terminals I redid the new fuse links Striped the ends ,crimped and sodered them they are caped with new covers. I think we should have a grounding diagram for the trouble shoot on this site. Quote Link to comment Share on other sites More sharing options...
