zmaster Posted March 27, 2008 Share Posted March 27, 2008 What is the amp rating for the fusible link for the EFI harness. These fusible links are the ones that come directly off of the positive terminal of the battery. Quote Link to comment Share on other sites More sharing options...
woldson Posted March 27, 2008 Share Posted March 27, 2008 Speaker wire 14gauge. I have no idea, just my friend did that a long time ago. Quote Link to comment Share on other sites More sharing options...
m4xwellmurd3r Posted March 27, 2008 Share Posted March 27, 2008 Don't do what woldson said. You'll burn something. Are you talking about the 4 fuseable links in those 2 boxes mounted on the fender? Those are the only ones I know of. If so, here's the ratings per year on those http://www.atlanticz.ca/zclub/techtips/fusiblelinks/index.html Quote Link to comment Share on other sites More sharing options...
woldson Posted March 27, 2008 Share Posted March 27, 2008 Sorry ment to have a LOL or something. Did do that before. The wire only lasted so long. It was less reliable than a fuseable link. I highly recommend that you only use oem or better parts in any car. Quote Link to comment Share on other sites More sharing options...
m4xwellmurd3r Posted March 27, 2008 Share Posted March 27, 2008 Sorry ment to have a LOL or something. Did do that before. The wire only lasted so long. It was less reliable than a fuseable link.I highly recommend that you only use oem or better parts in any car. Actually I'm a fan of getting rid of the fuseable links in place of using blade fuses. You can't find those stupid links hardly anywhere, and it's much easier to go to the local parts store and buying a box of 5 fuses for like 3 bucks. And it cleans up the engine bay. I plan on doing the same to my car soon. Quote Link to comment Share on other sites More sharing options...
woldson Posted March 27, 2008 Share Posted March 27, 2008 Yes. I melted my fuseable link case down. The fuseable links were toasty as well. Had to do the dangerous thing of "hard" wireing all the wires together untill I get a fuse block. Yep got a big ole wire nut on there. 83zx. Quote Link to comment Share on other sites More sharing options...
zmaster Posted March 27, 2008 Author Share Posted March 27, 2008 that still doesn't answer my question.... this may be the answer to all of my fuel pump problems....The sooner I can find out the answer to (WHAT AMP IS THE EFI FUSEABLE LINK) the sooner I can get my car on the road. Quote Link to comment Share on other sites More sharing options...
m4xwellmurd3r Posted March 27, 2008 Share Posted March 27, 2008 Actually that link DOES answer your question. You want to know the rating for the EFI fuseable link. that site tells you that. but I don't know what year yours is. It's different for different years. Quote Link to comment Share on other sites More sharing options...
zmaster Posted March 28, 2008 Author Share Posted March 28, 2008 i have a 1975 280z coupe... and no the fusible links are not the ones on the passenger fender.... I will Have to take pictures of what I am Talking about. I should have pics up after this weekend. Quote Link to comment Share on other sites More sharing options...
zmaster Posted March 28, 2008 Author Share Posted March 28, 2008 for the efi harness a wire come directly from the positive terminal of the battery and runs directly behind the engine, and into the firewall on the drivers side. Quote Link to comment Share on other sites More sharing options...
zmaster Posted March 28, 2008 Author Share Posted March 28, 2008 pics are really needed in this thread. Quote Link to comment Share on other sites More sharing options...
zmaster Posted March 29, 2008 Author Share Posted March 29, 2008 This is for everyone to know exactly what I am talking about I will have a few more pics up by monday morning. Quote Link to comment Share on other sites More sharing options...
zmaster Posted March 29, 2008 Author Share Posted March 29, 2008 us this pic You can see the text in the box. Quote Link to comment Share on other sites More sharing options...
zmaster Posted March 29, 2008 Author Share Posted March 29, 2008 What is this wire connection from the negative terminal of the battery that connects to the EFI harness?? And what is this red wire from the positive terminal of the battery going into the EFI harness?? Is the red wire a fusible link? If it is a fuseable link what amp is it, I will replace with newer fuses. More pics coming soon. Quote Link to comment Share on other sites More sharing options...
wal280z Posted March 29, 2008 Share Posted March 29, 2008 that still doesn't answer my question.... this may be the answer to all of my fuel pump problems....The sooner I can find out the answer to (WHAT AMP IS THE EFI FUSEABLE LINK) the sooner I can get my car on the road. Indirectly, the link did. That is, if you had one to verify the color of it. On my '77, there is a black link with two connectors on it held together by a nylon tie. Not for certain if it changed through the years. FWIW, the microfiche states for production years 8/76 - 7/77 P/N 24022-N4200 - 1 req'd per car for 8/77 up: P/N 24022-U8700 AND 24022-N7600, one each per car. (Info found: Fiche E8, 54B-3, item #45) What is this wire connection from the negative terminal of the battery that connects to the EFI harness?? provides a ground for the control unit. The reason it has a nylon connector? my guess is so the positive and negative connections to the control unit would not get mixed up. And what is this red wire from the positive terminal of the battery going into the EFI harness?? I can't say for certain from the picture you provided. I just checked mine, both the positive and negative leads from the control unit are heavy gauge red wires. Hope this helps. Wayne Quote Link to comment Share on other sites More sharing options...
zmaster Posted March 29, 2008 Author Share Posted March 29, 2008 FWIW, the microfiche states for production years 8/76 - 7/77 P/N 24022-N4200 - 1 req'd per car for 8/77 up: P/N 24022-U8700 AND 24022-N7600, one each per car. (Info found: Fiche E8, 54B-3, item #45) What does that mean??? what is FWIW and where do I go to eneter in the product number? Quote Link to comment Share on other sites More sharing options...
zmaster Posted March 31, 2008 Author Share Posted March 31, 2008 hello is anyone out there with the answer to my problems. Quote Link to comment Share on other sites More sharing options...
woldson Posted March 31, 2008 Share Posted March 31, 2008 Not me, I already suggested speaker wire and you did not listen,,,,,heee heee! Quote Link to comment Share on other sites More sharing options...
zmaster Posted March 31, 2008 Author Share Posted March 31, 2008 I want to use a fuse just in case there is to much current....I don't want a fire Quote Link to comment Share on other sites More sharing options...
woldson Posted April 1, 2008 Share Posted April 1, 2008 I have a wire nut because I want to do it right. All my connections will be redone and replaced with a splice block. What is the amp rating? I don't know and if I can not figure it out with the search button, than starting low will suffice for me. Of couse there will be a few extras laying around. Quote Link to comment Share on other sites More sharing options...
