fentin_fury Posted March 27, 2008 Share Posted March 27, 2008 Good morning, I need some assistance with torque and stretch measurements and hope someone here has them (no guessing please) RB26 Tomei H beam conrods - with the ARP L19 bolts (no specs in box) ARP head bolts #202-4207 (2000 series) - again no specs from ARP Called ARP and got some numbers for the head bolts but they seam too high 125ft/lbs. They refused to give a number for the Conrods. Even if someone can provide me a number for tomei USA that would be great. Q Quote Link to comment Share on other sites More sharing options...
jerryb Posted March 27, 2008 Share Posted March 27, 2008 What! you opened her up? Whats up? Quote Link to comment Share on other sites More sharing options...
fentin_fury Posted March 27, 2008 Author Share Posted March 27, 2008 found the number for Tomei Tomei Powered USA Inc. 13 Orchard, Suite 107, Lake Forest, CA 92630, USA. Tel: 949 855 6577 (+1 949 855 6577) Fax: 949 855 6525 (+1 949 855 6525 Quote Link to comment Share on other sites More sharing options...
fentin_fury Posted March 27, 2008 Author Share Posted March 27, 2008 jerryb said: What! you opened her up? Whats up? Oh yeah - complete rebuild. Tomei conrods, pistons, stage 2 cams, springs, adj. cam gears, fully ported head, tomei oil pump, hks gt-rs turbos, etc. etc. No - there was nothing wrong with the engine. Pictures out soon of the long block together. Also have the steering wrack almost done - will post some pics of that as well. Q Quote Link to comment Share on other sites More sharing options...
jerryb Posted March 27, 2008 Share Posted March 27, 2008 Oh OK.......steering rack? power? Quote Link to comment Share on other sites More sharing options...
fentin_fury Posted March 27, 2008 Author Share Posted March 27, 2008 jerryb said: Oh OK.......steering rack? power? i was thinking wreck - but yes a subaru power steering rack Quote Link to comment Share on other sites More sharing options...
jerryb Posted March 27, 2008 Share Posted March 27, 2008 I look forward to seeing the steering wreack installed! I'm thinking of doing the same. Im very curious what it does to the overall ride and handling....cant wait to hear your comments. Cheers! Quote Link to comment Share on other sites More sharing options...
fentin_fury Posted March 28, 2008 Author Share Posted March 28, 2008 Well spoke to Tomei Japan Here are the specs I was given: 1) Torque - 15Nm 2) Angle wrench - 60-65 degrees Stretch should be between 0.12-0.15 mm Q Quote Link to comment Share on other sites More sharing options...
75&78Z Posted March 28, 2008 Share Posted March 28, 2008 A quick question regarding rb rod bolt torque in general and I am asking it in regards to both stock and aftermarket bolts. When you disassemble the rod caps (used engine, checking bearing condition, etc) should you replace the rod bolts or can you reuse the bolts, and if its ok to retorque the "used" bolts is there a limit as to how many times you can do this before you should invest in new fasteners? Quote Link to comment Share on other sites More sharing options...
Careless Posted March 28, 2008 Share Posted March 28, 2008 that doesn't sound right for the ARP. Mine were boxed with a small piece of paper (or was that my spool rods?!) Quote Link to comment Share on other sites More sharing options...
Careless Posted March 28, 2008 Share Posted March 28, 2008 Standard RB26 manual states max of 76 - 83 ft. lbs. on standard head bolts. ARP states the following: http://www.arp-bolts.com/Catalog/Catalog.Pages/2005Catalog024.html 86 with ARP moly Lube. 120 with 30 weight oil. So that sounds right. I remember our resident member Dragonfly mentioning that you'd have to snap over a torque wrench at least 6 times before taking an accurate reading. So that may be something to consider. EDIT: Q, i'm not sure if you're doing the final assembly, but whoever is, here's some additional info to consider (bottom of the page) http://www.aptfast.com/ARP_Additional_Stuff/ARP_notes_info/arp_t_specs.htm there are some things I didn't consider when I took a look at that. They aren't in any of the 3 assembly books I've read either. Quote Link to comment Share on other sites More sharing options...
Careless Posted March 28, 2008 Share Posted March 28, 2008 75&78Z said: A quick question regarding rb rod bolt torque in general and I am asking it in regards to both stock and aftermarket bolts. When you disassemble the rod caps (used engine, checking bearing condition, etc) should you replace the rod bolts or can you reuse the bolts, and if its ok to retorque the "used" bolts is there a limit as to how many times you can do this before you should invest in new fasteners? I've heard of people reusing them, but rod bolts tend to be the weakest link in these motors... sooooooo, pick your pill! Quote Link to comment Share on other sites More sharing options...
fentin_fury Posted March 29, 2008 Author Share Posted March 29, 2008 Careless said: Standard RB26 manual states max of 76 - 83 ft. lbs. on standard head bolts. ARP states the following: http://www.arp-bolts.com/Catalog/Catalog.Pages/2005Catalog024.html 86 with ARP moly Lube. 120 with 30 weight oil. So that sounds right. I remember our resident member Dragonfly mentioning that you'd have to snap over a torque wrench at least 6 times before taking an accurate reading. So that may be something to consider. EDIT: Q, i'm not sure if you're doing the final assembly, but whoever is, here's some additional info to consider (bottom of the page) http://www.aptfast.com/ARP_Additional_Stuff/ARP_notes_info/arp_t_specs.htm there are some things I didn't consider when I took a look at that. They aren't in any of the 3 assembly books I've read either. You are correct for the head bolts - the specs I quoted were for the conrod bolts. Q Quote Link to comment Share on other sites More sharing options...
Careless Posted March 29, 2008 Share Posted March 29, 2008 my ARP 2000s came with a paper saying 43lbs. :-/ so if you find something around there it would probably be right... just to aid in the search Quote Link to comment Share on other sites More sharing options...
