ozzinc Posted April 18, 2008 Share Posted April 18, 2008 I have a 72 240z that I just purchased coilovers for, and I did not think about the struts that I would use, the upper collars on some coilovers are different so I may have to do some drilling for the fitment of the strut to fit into the collar, what would be the best solution to matching the coilovers to the struts and to drilling the upper collar for fitment. Quote Link to comment Share on other sites More sharing options...
johnc Posted April 18, 2008 Share Posted April 18, 2008 What upper collar? Do you mean the upper spring perch? Quote Link to comment Share on other sites More sharing options...
1 fast z Posted April 18, 2008 Share Posted April 18, 2008 I think he is talking about the monoball. Yes we use different bushings to adapt different struts. Quote Link to comment Share on other sites More sharing options...
ozzinc Posted April 21, 2008 Author Share Posted April 21, 2008 yep thats what im talking about, its that monoball, where do I get the correct bushings for the upper spring perch Quote Link to comment Share on other sites More sharing options...
1 fast z Posted April 21, 2008 Share Posted April 21, 2008 Custom. Just take your dimensions to a machine shop, should be about 50.00. Quote Link to comment Share on other sites More sharing options...
ozzinc Posted April 21, 2008 Author Share Posted April 21, 2008 by the way I actually have the fully adjustable lower control arms, do i really need the camber plates that I have for negative camber adjustment, If I can use the lower control arms for adjustment. Quote Link to comment Share on other sites More sharing options...
1 fast z Posted April 22, 2008 Share Posted April 22, 2008 I have adjustable lower controll arms also, WITH camber plates. I run -1 degree camber in the front, with the camber plates all the way positive. Then when I go to the track, I just loosen the camber plate bolts, and slam the camber to the limits, which is 2 degrees, so I get 3 degrees negative at the track. Then when you wanna go home, just pull the camber back out to -1 degree. Quote Link to comment Share on other sites More sharing options...
ozzinc Posted April 25, 2008 Author Share Posted April 25, 2008 Can I Actually Purchase The Upper Spring Perch With A Monoball, I Have Seen Some Sites That Sell The Spherical Bearing In Two Sizes I Have The Bilstein P30-062 And The Tokico Hz3015 Struts. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted April 25, 2008 Share Posted April 25, 2008 Take your caps lock off and maybe show us a link. Sound like a camber plate without the camber adjustment, which seems like it's almost a good idea. Quote Link to comment Share on other sites More sharing options...
ozzinc Posted April 25, 2008 Author Share Posted April 25, 2008 Take your caps lock off and maybe show us a link. Sound like a camber plate without the camber adjustment, which seems like it's almost a good idea. I will show you a photo of what I have jim Quote Link to comment Share on other sites More sharing options...
ozzinc Posted April 25, 2008 Author Share Posted April 25, 2008 I mean jon , where in the hell did I get jim from, must be to much star strek. Quote Link to comment Share on other sites More sharing options...
ozzinc Posted April 27, 2008 Author Share Posted April 27, 2008 I tried to upload some photos, but the site keeps telling me that your file exceeds the forum's limit of 976.6 kb for this file type Quote Link to comment Share on other sites More sharing options...
93anthracite Posted April 29, 2008 Share Posted April 29, 2008 I tried to upload some photos, but the site keeps telling me that your fileexceeds the forum's limit of 976.6 kb for this file type Must be a big file You might want to open an account with an online photo host (I use photobucket) and then you can just link the picture to your posts here without having to load them onto the thread itself. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted April 29, 2008 Share Posted April 29, 2008 You need to get a tool that allows you to shrink down your photos. Web photos need only be about 72 dpi. Your photo that comes out of your camera is probably thousands of dpi. That's important when you're printing photos, but when you're just displaying them on the web it's extreme overkill. There are a ton of different applications to reduce your photo size. Find one and use it. Quote Link to comment Share on other sites More sharing options...
mom'sZ Posted April 29, 2008 Share Posted April 29, 2008 Most the time the manufacturer of the coil over kit should provide the correct bushing for the struts you are using. Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted April 29, 2008 Share Posted April 29, 2008 http://www.irfanview.com/ This is a fantastic program for resizing and some photo editing. Its FREE and ive been using it for years! Quote Link to comment Share on other sites More sharing options...
