new center console
rdsk8ter
not sure if this is where this should go feel free to move it
Im going to make a custom center consoleand need to know what switches do you all think I need. Im thinking start, ign, fuel pump, fogs, neons inside, inside dome light anything else that you can think of. Im not going to run undercar lights I dont think, might but yea I could tie them into the neons inside they would be only show anyway. I appreciate any input. I am going to be using the car for shows and 1/4 mile runs weekend warrior
I work at a local car audio shop and we sell both under body neons and LED's. I would heavily recommend under body LED's over the neons, in fact LED's over neon inside as well. The neon will break, period, they do not bend so the light you want is difficult to achieve, and finally they consume more power than the LED's. Lol, just my imput from experience.
a switch for your electric antena, emergency lights, rear defoger, and lets not forget the passenger injection seat.
lol ill put a little motor inder the passanger seat so they feel it vibrate. not going to run a rear defogger or antena might do a hidden amplified one as far as the leds ya ill run those if i run any didnt remember they made those lol thanks guys
I was thinking of doing the same thing with the neons under the car, but decided against it 2 reasons, its a classic car, and two there is no room at the rear of the z because the gas tank is to close to the back of the car so you would only be ablle to run 3 neons under the car. I am still considering a few neons inside the car for some accent lighting.
i dont think ill go undercarrage lights but i am going to go either led or neon inside
here is how mine looks right now still going on it though
Nice. What did you use to shape? Foam board? I need to redo mine interior when I'm done with everything else. Got a couple of 10" MTX that some one gave me, that I haven't done anything with in a while.
acutally cardboard for the main section ducttaped together and then used blue tape over that because i had a ton left over from some painting around the house. I made the actual subwoofer holer out of mdf. its actually really easy just make sure you match the sides together. Ive also seen people use chickenwire, foam, tape alone etc etc. Just make sure if you use foam to cover it well fiberglass will melt it.
another good way to do it is with fleece material. It will stretch and not wrinkle........just add resin and some fiber if needed for extra support....
the problem with that is if you have no backing and its floating off the floor what are you suppose to attach to?
to do the fleece yuou have to first cut out an opening for the sub to sit on to, then make a tri pod for the ring the sub sits in or on, and then lay the fleece over the ring and staple it to the 3/4 inch base, and then you can start to fiberglass.thats the method I was going to do
Like this
http://www.the12volt.com/installbay/forum_posts.asp~TID~74519~PN~1
the only thing that wouldntdo is the back is what i was getting at
yes just lkike that. but on the downside, I will have to do all of this inside of my car, I don't think I will be able to take it out, right now I am working on how I will take it out of the car. I might just cut the base smaller, and cut the legs that angle the outer sube just a little shorter. i will asess the whole subwoofer situation either tonite if i go to my garage, or tomarrow morning.
