skewie09 Posted April 27, 2008 Share Posted April 27, 2008 When I start my Z if I tap on the gas pedal it putts and wants to die, about 2 min. of driving its fine, but I have a ticking noise and I notice a loss of HP, after driving for about 30 min. the ticking goes away. Oh yeah, also when I park the car it smells kinda like a rotten egg almost like somethings burning(as if metal). Running too rich? Burned cat? Quote Link to comment Share on other sites More sharing options...
plexus Posted April 27, 2008 Share Posted April 27, 2008 heard the cats smell like that when there toast the battary can smell like that if its over charged by the alt learned that frieing a battery on a tarus ( i miss that car sometimes). the ticking is it low or high(coming from crank or head area)? Quote Link to comment Share on other sites More sharing options...
skewie09 Posted April 27, 2008 Author Share Posted April 27, 2008 Ticking is near the head area and it ticks with the motor. I took it to a mech. and they said it was not the lifters Quote Link to comment Share on other sites More sharing options...
80LS1T Posted April 29, 2008 Share Posted April 29, 2008 Sounds like you have an exhaust manifold leak. This would explain everything...ticking only for a while because once the manifold and head heat up they expaned and seal it self up...the smell is probably from the leak...and the loss of power could be do to your o2 not reading correctly due to an exhaust leak. I would check your exhaust/intake manifodl gasket for leaks(same gasket) and it thats it.........have fun! LOL Guy Quote Link to comment Share on other sites More sharing options...
skewie09 Posted April 29, 2008 Author Share Posted April 29, 2008 if it is the exhaust manifold .....instead of taking the whole thing apart, is there a way to check this problem without the tear down? Quote Link to comment Share on other sites More sharing options...
Gollum Posted April 29, 2008 Share Posted April 29, 2008 Well inspect the bolts, might need a mirror to see them all. Also look for any black areas, as the exhaust leak will leave surrounding areas black. It's not too uncommon for the furthest front and back exhaust bolts to break, I've now owned 2 L motors like this. It shuoldn't be "too" hard to just pull the intake manifold and give the exhaust manifold a good inspection. I can easily remove an intake in about 30 minutes providing all the tools for it are out and ready. Quote Link to comment Share on other sites More sharing options...
