GMC1500 Brake rotors/pads suggestions
JMortensen
I warped the front rotors on my 2006 GMC1500 4x4, I think it happened when I towed my friend's S10 Blazer on my trailer. That was a lot of weight behind the truck and I had a couple long downhill stops from relatively high speeds.
Anyway, rather than screw with turning the rotors and all that I'm just going to replace them. I've looked and it appears you can get Brembo rotors, which I'll do because they lasted so well on the Z, but I have no clue as to what would be the best brake pad for this application. It will be used as a tow vehicle and I drive it maybe 5000 miles/yr on the street. Pad longevity is not a concern, I just want something that doesn't warp the rotors with the type of use I'll put them through.
Suggestions?
