t-5 hydrualic and bellhousing questions.
fl327
this is my real curiosity, will a wct5 bolt up to the same bellhousing as a muncie??? im using a lakewood scattershield in my setup.
would the same hydraulic setup also work?
im using a 1"tilton mc to the datsun stock slave with a modified pushrod.
I'd imagine the bellhousing you have for the Muncie is the straight up one. There is also one for the WCT5 to work in the Camaros that used the T5 (previous generation).
The F-body WCT5 bolt pattern is the same as the Muncie and T-10 though. In fact, you might want to use the straight up bellhousing as it places the shifter nicely in the center of the tunnel, as opposed to to the left of the hole. The only issue is building an angled mounting scheme for the trans mount. Pretty easy to do.
The hydraulic setup should not depend on the transmission, only the clutch and changes if any in the clutch fork geometry.
