Sound familiar?
So i FINALLY got my cams back from frickin Isky today, and heres the specs:
INTAKE TIMING
Duration:256
Open: 9 before TDC
Close: 67 After BDC
Cam lift: .281
Valve lift: .425
Valve Lash: .000
Exhaust
Duration:256
Open: 67 Before BC
Close: 9 After TDC
Cam Lift: .281
Valve Lift: .425
Valve Lash: .000
Overlap: 18 Deg.
Taken at .050 Lifter Rise
Intake Duration: 202 Deg Exhaust Duration: 202
Open: -18 before TDC Open: 40 Before BDC
Close: 40 After BDC Close: -18 AFter TDC
Sound like a good grind for a NA VG30e?
Also, it states that its mandatory to use a additive or oils containing zinc/phosphorus for break-in and its recommended thereafter, and that on initial startup i should rev to 2,500 rpms and hold it for 10-15 minutes, but does this apply to OHC nissan motors? the form they sent was for a pushrod chevy motors (it stated that the cam relies on motor oil "splash" from the connecting rods so its gotta be a pushrod motor) and also mentioned it was for flat-tappet hydraulic and solid lifter cams...
also any advice on installing cams would be appreciated!
ALL bedding in of high friction areas should be broken in with a high ZDDP oil as far as I've read.
Rotella T Diesel oil is generally good to run for the first 100-500 miles. Just take it really easy and shift at no less than 2000, and try to cruise at 3000.
eas across the rev-range, AFTER you've bed in the cam as per instructions.
Do you have new lifters? you might as well.
