Guest kjvildal Posted June 13, 2008 Share Posted June 13, 2008 1981ZX blew a header gasket. After rebuilding the engine and replacing the gasket we must have missed something in the re-assembly. Car starts Car will idle smoothly The minute you put your foot to the acellerator the car runs SOOOO rough and putts and spits (sounds like a propeller plane taking off) Car will roll and run a little without giving gas with the pedal, but you give it gas it goes very slow and sounds like it is preparing for take-off) One thing missing right now is the EGR pipe - it broke but I don't think that is the main problem Thank you for your input Quote Link to comment Share on other sites More sharing options...
Guest n3mi5y5 Posted June 14, 2008 Share Posted June 14, 2008 it blew the head gasket? im not sure what you mean by header gasket.... the only thing that i could think of that could be wrong is you didnt torque it down good enough, or there was some residue leftover from the previous gasket... usually when you replace the head gasket its a good idea to take the head to a machine shop to get decked and then reinstall. Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted June 14, 2008 Administrators Share Posted June 14, 2008 Kjvildal, One post, in one thread is adequate. Please refrain from cross posting. Quote Link to comment Share on other sites More sharing options...
islanddozer Posted June 15, 2008 Share Posted June 15, 2008 The egr pipe is a major loss of vacum. fix that first and if not that could be throttle vavle switch needs adjustment. good luck Quote Link to comment Share on other sites More sharing options...
Chemicalblue Posted June 15, 2008 Share Posted June 15, 2008 Check your firing order. If the plug wires are wrong, then most likely the dizzy is off alignment too. I had a friends dad do the same thing once. It was actually really crazy how he swapped wires until it ran. When I told him the firing order, he fixed that and then tried starting the car (after I said not too). It made the loudest back fire Ive ever heard. So double check all your timing before hooking up your injector clips, it will save you lots of trouble. As for the EGR cap it off first or hook it up. Quote Link to comment Share on other sites More sharing options...
BSD Posted June 15, 2008 Share Posted June 15, 2008 REPOST, sorry! Quote Link to comment Share on other sites More sharing options...
BSD Posted June 15, 2008 Share Posted June 15, 2008 I think he means to say Exhaust manifold gasket, unless he has actual headers.. I would go with what chemicalblue said, if you have an exhaust leak it will screw the car, check your spark plugs, wires.. etc.. Quote Link to comment Share on other sites More sharing options...
DuoWing Posted June 16, 2008 Share Posted June 16, 2008 I'm assuming he meant the exhaust manifold gasket as well. Since he said it sounds like a propeller plane. When my exhaust manifold gasket was leaking, I always described it as a ticking that sounded like a Harley or something. Is the car a turbo? If your EGR tube is broken that will affect it. Basically the car will start and idle smoothly because the BCDD or VCM depending on car prevents the EGR from opening. Then once you start to rev it, the thing will allow the EGR to open and start causing a huge vacuum leak. Try removing the vacuum line from the EGR valve on the manifold and just plugging that line off, and see if that helps. The leaking manifold gasket I don't think makes too much difference. Or at least it didn't make much difference on my leaking or fixed. It still ran the same for me, but I was happy knowing that it and the broken stud were fixed. Quote Link to comment Share on other sites More sharing options...
