78280z Posted June 16, 2008 Share Posted June 16, 2008 I have read that the rocker panels and quarter panels provide much of the structural support of the Z's unibody. Since I will be replacing both rocker panels and rear quarters on my Z, I am wondering how to go about ensuring that the unibody does not come out of alignment while I am replacing the panels. Any suggestions? Thanks in advance for any advice! Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted June 16, 2008 Share Posted June 16, 2008 For the rocker panels - put an X-brace in the door (do one at a time). For the quarter panel, I would just have it on jack stands... Quote Link to comment Share on other sites More sharing options...
johnc Posted June 16, 2008 Share Posted June 16, 2008 Do one panel replacement at a time and weld in the X brace per Brad's suggestion. If you can pull the engine and transmission that will remove some load on the chassis. Quote Link to comment Share on other sites More sharing options...
rturbo 930 Posted June 17, 2008 Share Posted June 17, 2008 Do one panel replacement at a time and weld in the X brace per Brad's suggestion. If you can pull the engine and transmission that will remove some load on the chassis.While we're on the topic - would it be ok to replace one side without the x-brace if it's just a BARE shell, on a rotisserie? Looks like I should have researched this a bit more... Quote Link to comment Share on other sites More sharing options...
johnc Posted June 17, 2008 Share Posted June 17, 2008 would it be ok to replace one side without the x-brace if it's just a BARE shell, on a rotisserie? I wouldn't do it. I've done three rotisserie floor pan and rocker panel replacements on 240Z shells and I always weld in an X in both doors before I start any work on the car. I weld them in with the door shut and then remove the door. Quote Link to comment Share on other sites More sharing options...
rturbo 930 Posted June 17, 2008 Share Posted June 17, 2008 I wouldn't do it. I've done three rotisserie floor pan and rocker panel replacements on 240Z shells and I always weld in an X in both doors before I start any work on the car. I weld them in with the door shut and then remove the door.Is it likely my car may now be misaligned if I did not put in any bracing? If so, it looks like I will be doing quite a bit of extra work. Quote Link to comment Share on other sites More sharing options...
johnc Posted June 17, 2008 Share Posted June 17, 2008 Is it likely my car may now be misaligned if I did not put in any bracing? I don't know. The body measurements diagram has been scanned and is posted somewhere here on the site. Do a search and then check the numbers on your car. Quote Link to comment Share on other sites More sharing options...
