VinhZXT Posted August 19, 2001 Share Posted August 19, 2001 Hi all, How do you replace the mustache bar bushing? I didn't order the new bushing yet but I did burned out the old one and seem like there is no way you can remove the metal part around the bushing. Do I need to remove that part or no? Thanks for any help Quote Link to comment Share on other sites More sharing options...
pparaska Posted August 19, 2001 Share Posted August 19, 2001 LEAVE THE METAL PART IN! Sorry to shout. I foolishly took the metal part out (that wasn't easy either) and had to make up a new cylinder, etc. to put in on my first mustache bar. Quote Link to comment Share on other sites More sharing options...
Miles Posted August 19, 2001 Share Posted August 19, 2001 Re: replacing bushings in the mustache bar: Today I bought a set of bushings from the Nissan dealer and had a shop press them into my 78 R200 mustache bar. By the way, my 78 R200 mustache bar has a slight upward twist to it. is that normal? Quote Link to comment Share on other sites More sharing options...
pparaska Posted August 19, 2001 Share Posted August 19, 2001 Yes, the twist is normal. Why did you go with the stock rubber mounts and not the Urethane? Quote Link to comment Share on other sites More sharing options...
Miles Posted August 20, 2001 Share Posted August 20, 2001 Why stock mounts? They were free. We are re-doing an old Scarab 350/240z conversion and plan on updating all of the bushings as we go through the car. What is the best source for the bushing kits? BTW is there any easy way to get at the driveline flange bolts? Quote Link to comment Share on other sites More sharing options...
pparaska Posted August 20, 2001 Share Posted August 20, 2001 I sound like a Motorsport Auto salesman lately, but I actually don't buy much of anything from them. BUT, I think it was their flier that had a complete assortment for sale. The reason I asked "why stock" is that more that a few people have found that the stock bushings allow too much movement of the diff, and end up breaking down and getting to a point of metal to metal pounding. Quote Link to comment Share on other sites More sharing options...
VinhZXT Posted August 20, 2001 Author Share Posted August 20, 2001 Pete, Thanks for the info. I did attempt to remove it before burning down the rubber. It's all make sense now.. heheh.. thanks Vinh Quote Link to comment Share on other sites More sharing options...
DavyZ Posted August 20, 2001 Share Posted August 20, 2001 Vinh, did you use a torch or what to burn that baby? Davy Quote Link to comment Share on other sites More sharing options...
Miles Posted August 20, 2001 Share Posted August 20, 2001 Sanity check before we lug the R200 up the mustache bar. We installed a 78 R200 mustache bar with the mounting rings facing the front of our 72 240z. Is this the correct orientation of the mustache bar or should the rings of the 78 bar face the rear in a 72z? Please yes as it was a b--ch getting the bar installed. Quote Link to comment Share on other sites More sharing options...
auxilary Posted August 20, 2001 Share Posted August 20, 2001 I got a set of polygraphite bushings from www.p-s-t.com, it cost me $180 shipped to my door, but this is front kit only. What's really nice is that the kit includes new lower ball joints and tie rod ends (the actual cast iron parts, not just bushings!). Beauty about polygraphite is that they don't need to be relubed like polyurethane. Quote Link to comment Share on other sites More sharing options...
VinhZXT Posted August 20, 2001 Author Share Posted August 20, 2001 DavyZ, Yes I used the torch to burn it. You have to knock the center metal piece out before you can burn it. Vinh Quote Link to comment Share on other sites More sharing options...
