Inaccurate fuel gauge
JhnRX7
My fuel gauge is not reading correctly. When I fill the tank it only reads 3/4 of a tank. it also occasionally "wobbles" quite a bit, about 1-2mm in each direction. Any ideas on what could be wrong? bent floater rod in the gas tank?
Absolutely believe you!
Oddly if you leave out that one irratation than all other restoration jobs may not be so pleged. I now this sound supersitiuos and now knock on wood.
Engage the meat and potatos frist, then whip the cream filling later.
My fuel gauge does something similar. when it's empty, it reads as FAR as the gauge can (way way under E) when it's full it reads about a half tank. BUT I can't really trust it too much. I'm going to pull the sender out and see what's goin on with it. I don't mind it being stupidly inaccurate though haha. it's one of her quirks I like.
if you really want, the fsm actually has specs that tell where it is supposed to be at certail points. it may require bending the rod the float is on, but it will be accurate. mine does that too, but i dont feel like pulling my tank out, not really worth it yet unless the odo breaks.
Same here. I already replaced my sending unit and o-ring with OEM Nissan parts because the old one had gone south long before I bought the vehicle. My new parts only read half full when the tank is completely full. I just brazed the fuel vent line back onto my tank and while I was there, bent the float rod a little to try and compensate. I'll see if it was successful on my next fillup. Mine isn't too difficult to reach, but its a '72.
