JhnRX7 Posted June 29, 2008 Share Posted June 29, 2008 My fuel gauge is not reading correctly. When I fill the tank it only reads 3/4 of a tank. it also occasionally "wobbles" quite a bit, about 1-2mm in each direction. Any ideas on what could be wrong? bent floater rod in the gas tank? Quote Link to comment Share on other sites More sharing options...
woldson Posted June 29, 2008 Share Posted June 29, 2008 Unless you realllly want to fix it, can you just live with it? As long as you can tell when your near empty just call it character! Quote Link to comment Share on other sites More sharing options...
JhnRX7 Posted June 29, 2008 Author Share Posted June 29, 2008 I have been living with it, and your right, its really not that big of a deal. However I have recently began to restore the car and this is one of those little things I would like to get fixed. Quote Link to comment Share on other sites More sharing options...
woldson Posted June 30, 2008 Share Posted June 30, 2008 Absolutely believe you! Oddly if you leave out that one irratation than all other restoration jobs may not be so pleged. I now this sound supersitiuos and now knock on wood. Engage the meat and potatos frist, then whip the cream filling later. Quote Link to comment Share on other sites More sharing options...
m4xwellmurd3r Posted June 30, 2008 Share Posted June 30, 2008 My fuel gauge does something similar. when it's empty, it reads as FAR as the gauge can (way way under E) when it's full it reads about a half tank. BUT I can't really trust it too much. I'm going to pull the sender out and see what's goin on with it. I don't mind it being stupidly inaccurate though haha. it's one of her quirks I like. Quote Link to comment Share on other sites More sharing options...
SHADY280 Posted July 7, 2008 Share Posted July 7, 2008 if you really want, the fsm actually has specs that tell where it is supposed to be at certail points. it may require bending the rod the float is on, but it will be accurate. mine does that too, but i dont feel like pulling my tank out, not really worth it yet unless the odo breaks. Quote Link to comment Share on other sites More sharing options...
blue72 Posted July 7, 2008 Share Posted July 7, 2008 Same here. I already replaced my sending unit and o-ring with OEM Nissan parts because the old one had gone south long before I bought the vehicle. My new parts only read half full when the tank is completely full. I just brazed the fuel vent line back onto my tank and while I was there, bent the float rod a little to try and compensate. I'll see if it was successful on my next fillup. Mine isn't too difficult to reach, but its a '72. Quote Link to comment Share on other sites More sharing options...
280zx 2by2 Posted July 8, 2008 Share Posted July 8, 2008 wow i cant even tell how much gas is in my tank at all(and my tank isnt rusty)... zx tank sending units must suck!!!!! Quote Link to comment Share on other sites More sharing options...
woldson Posted July 8, 2008 Share Posted July 8, 2008 No, that is the job of the fuel pump. I've not read too many posts about it being a problem. My own experience with my 82 and 83 is they are very reliable. Quote Link to comment Share on other sites More sharing options...
Gollum Posted July 16, 2008 Share Posted July 16, 2008 I've owned 4 280ZXs... They've all had very accurate fuel guages. It might just be that the sending unit needs to be cleaned up. I've never had an issue, so I've never opened up my tank. Quote Link to comment Share on other sites More sharing options...
JhnRX7 Posted July 19, 2008 Author Share Posted July 19, 2008 I was going through my receipts and the previous owner replaced the gas tank. So im assuming that whoever installed it bent the floating rod or messed up the sending unit somehow. Quote Link to comment Share on other sites More sharing options...
