jc052685 Posted July 11, 2008 Share Posted July 11, 2008 just ordered my turbo today from turbochargers.com (retail location) and they said it should be in as early as tuesday. Thats goo because I want to get the turbo on by friday and have the car driving as i am going to Austin for the Texas Nissans meet on saterday. May even have time to throw it on the dyno for a good tune. I am currently running a stock RB25det turbo on my L28et. That turbo got me 197whp and 285wtq on like a 95deg day @ 12psi. I thought that was a fairly decent number. Well anyway I should be getting the 62-1 stage 5 compressor on tuesday so maybe I will have some dyno numbers before the weekend is over. Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted July 14, 2008 Share Posted July 14, 2008 Would that be a 62-1 Compre4ssor with a STage 5 Turbine Trim? If so you have a badf mismatch between turbo specs and cam specs. You really will need a bigger cam to get it to work well at the higher rpms that the turbo will make power/boost at. The stock cam starts to peter out at 5300 rpm and that is just where your new turbo will start making full boost. Quote Link to comment Share on other sites More sharing options...
WizardBlack Posted July 23, 2008 Share Posted July 23, 2008 Would that be a 62-1 Compre4ssor with a STage 5 Turbine Trim? If so you have a badf mismatch between turbo specs and cam specs. You really will need a bigger cam to get it to work well at the higher rpms that the turbo will make power/boost at. The stock cam starts to peter out at 5300 rpm and that is just where your new turbo will start making full boost. I don't see any problem with upgrading on piece at a time. Quote Link to comment Share on other sites More sharing options...
