cleton-z Posted July 14, 2008 Share Posted July 14, 2008 so i am swapping a 2j into a 240 for a friend of mine and he wants to use the 2j stock wire harness instead of going standalone which he already has but since he will be living in california he wants to keep the 2j as stock as possible so i wanted to know if someone has done the wiring before and did not post it up and any info that you guys can send my way will be helpful he does not want to use a standalone but if i cant find any info on the harness he might have to Quote Link to comment Share on other sites More sharing options...
timbo1jz Posted July 15, 2008 Share Posted July 15, 2008 I am going to be using a 1jz engine harness with a painless body harness for my 1jz swap. Not a 2jz but almost identical. Quote Link to comment Share on other sites More sharing options...
loy Posted July 15, 2008 Share Posted July 15, 2008 Just wondering is the 2j usdm or jdm? Quote Link to comment Share on other sites More sharing options...
cleton-z Posted July 15, 2008 Author Share Posted July 15, 2008 the 2j is jdm Quote Link to comment Share on other sites More sharing options...
Tengu3 Posted July 17, 2008 Share Posted July 17, 2008 I have a question, please. What do "1j" "1jz" and "2j" "2jz" mean? I'm hoping to buy a new wiring harness for my 1973 240-Z rebuild, and wonder if those terms refer to something I should know about. Thanks! James Quote Link to comment Share on other sites More sharing options...
ragefear Posted July 17, 2008 Share Posted July 17, 2008 http://en.wikipedia.org/wiki/Toyota_JZ_engine there you go! BTW, thats gonna be sooooooo sick! Quote Link to comment Share on other sites More sharing options...
ShaggyZ Posted July 17, 2008 Share Posted July 17, 2008 They don't mean anything really. Just a designation like 7MGTE and 6MGE. 1JZ was the first of the JZ engines and 2JZ the second. Quote Link to comment Share on other sites More sharing options...
jkgts1 Posted July 26, 2008 Share Posted July 26, 2008 I think that each number and letter stand for something, like what block, head, t for turbo..... I know between the 5sfe and 3sgte, the "f" and the "g" designate different heads. "f" being a non-performance head and "g" being the opposite, I am pretty sure they have different valve angles. The "s" if I remember correctly is the block, which is the same in these two engines. I would assume the the 1jzgte and 2jzgte is similar. Quote Link to comment Share on other sites More sharing options...
Guest YoshiFD3S Posted September 1, 2008 Share Posted September 1, 2008 1JZ-GTE = 2.5L "280hp" Inline 6, most COMMONLY known for coming in the Toyota Soarer (Lexus SC300), but is also known to come in the MKIII Toyota Supra. The 2JZ-GTE = 3.0L "320hp" Inline 6, most COMMONLY known for coming in the Toyota Supra, but is also known to come in the Toyota Aristo, which is commonly the version of the 2JZ that you see for sale on Ebay. The Aristo 2JZ is cheaper mainly because it's always going to come automatic, has different turbos, and smaller injectors than the Supra 2JZ. The 6-speed that comes with the Supra 2JZ in itself is valued around $3,000.. Quote Link to comment Share on other sites More sharing options...
cleton-z Posted September 2, 2008 Author Share Posted September 2, 2008 so anyway i found a guy that will rewire and graft the jz wire harness into the z and he also custom makes front facing intakes for the rb25 if anyone wants his number just pm me and i will pm you his number Quote Link to comment Share on other sites More sharing options...
