Z2000 Posted July 18, 2008 Share Posted July 18, 2008 What fuel pumps are commonly used for modern pressure fuel injected swaps? In line? In tank? I have a 73 Z and I also realized the fuel return line was small... Is it standard to upgrade to a larger fuel return line in this case? Thanks Quote Link to comment Share on other sites More sharing options...
duder280z Posted July 18, 2008 Share Posted July 18, 2008 I am using a Walbro model 392 which seems to be the norm. I got mine for $120. shipped and it dropped right in without too much fuss. The return line will be an issue, at least with a hi flow pump like this one. If you do a search you should be able to find all sorts of info in that regard. Quote Link to comment Share on other sites More sharing options...
Mayolives Posted July 18, 2008 Share Posted July 18, 2008 What kind of power will you be making? If you plan to make a bunch, I would plan on running larger feeder and return lines. The pump manufacturer can recommend sizes for you. I running a -8 from the Aeromotive pump and a -6 for the return. (http://www.aeromotiveinc.com) Quote Link to comment Share on other sites More sharing options...
Six_Shooter Posted July 18, 2008 Share Posted July 18, 2008 I am currently installing a Walbro 255 L/hr (GL392 IIRC) on my '73, I'll post pictures later if you like. I made a new mount for the pump, since I didn't like ow far into the wheel weel the line would be if I had use the original electric fuel pump mount (looks like it was that 1973 dealer add-on pump and mount). I am leaving the original lines in place, using the originla feed for return, since it's 5/16", and added a new feed line of 3/8" I removed the drian plug from the tank, ran a 1/4" NPT tap into the drain hole and then added a 90* fitting that would then accept the 3/8" double flare line. I know other people that have used this pump or the intank version with quite a bit of success. I bought mine from expressfuelpumps.com , or expresspumps.com I can get the actual URL later. Quote Link to comment Share on other sites More sharing options...
Z2000 Posted July 18, 2008 Author Share Posted July 18, 2008 thanks for the replys! Can the larger fuel lines be robbed from a newer year fuel injected Z? or should I just go custom with them? Is this 392 fuel pump inline or in tank? Im guessing inline. Quote Link to comment Share on other sites More sharing options...
duder280z Posted July 19, 2008 Share Posted July 19, 2008 thanks for the replys! Can the larger fuel lines be robbed from a newer year fuel injected Z? or should I just go custom with them? Is this 392 fuel pump inline or in tank? Im guessing inline. I would think new lines would be cheaper, easier, and more reliable, but I can't speak from experience on that. The pump is inline, very simple to put in. Quote Link to comment Share on other sites More sharing options...
