Phantom Posted August 5, 2008 Share Posted August 5, 2008 The JCI compressor is a high efficiency unit that uses about 25% less energy than a standard OEM - or that's what I remember him telling me several years ago. I'm not sure the RPM issue would be significant with it. I notice my LS1 dropping maybe 50 RPM when it kicks in but that has not caused me any problems. Quote Link to comment Share on other sites More sharing options...
Danno74Z Posted August 8, 2008 Share Posted August 8, 2008 http://www.ls1tech.com/forums/showthread.php?t=938768&highlight=ac+request Bart, Go to this link above and I believe you question will be answered. If I under stand the logic your ECM needs to know when to bump the idle and this is done through 3 lines on the LS1 ECM. RED 14 Pressure Sensor, 17 AC request, 18 AC clutch voltage. I believe all three have to be used to get the PCM to bump the idle. From that thread above the pressure sensor is a key component to getting the ECU to increase RPM. Danno74Z Quote Link to comment Share on other sites More sharing options...
Bartman Posted August 8, 2008 Share Posted August 8, 2008 http://www.ls1tech.com/forums/showthread.php?t=938768&highlight=ac+request Bart, Go to this link above and I believe you question will be answered. If I under stand the logic your ECM needs to know when to bump the idle and this is done through 3 lines on the LS1 ECM. RED 14 Pressure Sensor, 17 AC request, 18 AC clutch voltage. I believe all three have to be used to get the PCM to bump the idle. From that thread above the pressure sensor is a key component to getting the ECU to increase RPM. Danno74Z Thanks Danno, you hit on the exact problem I was running into. I think putting in an AC pressure sensor will give me the information I was missing to make the PCM realize I'm running AC. Quote Link to comment Share on other sites More sharing options...
Danno74Z Posted August 8, 2008 Share Posted August 8, 2008 Hi Bart, Glad to help a little. I think this will also help: http://www.ls1tech.com/forums/showthread.php?t=962124&highlight=ac+request Go down to the 6th reply and this fellow has a Vintage Air System and if you email him he may be able to tell you exactly what to do! Those guys on LS1Tech are very knowledgeable too. Danno74Z Quote Link to comment Share on other sites More sharing options...
yiannit280z Posted June 9, 2020 Share Posted June 9, 2020 On 7/20/2008 at 4:48 PM, rwwisnesky said: http://members.cox.net/chipsbyal/page/project/280z/index.htm It looks like a clean install for the A/C I know this is a long shot but ive been using this picture for reference and is no longer available. Could you re upload some pics? Thanks Quote Link to comment Share on other sites More sharing options...
ZHoob2004 Posted June 9, 2020 Share Posted June 9, 2020 2 hours ago, yiannit280z said: I know this is a long shot but ive been using this picture for reference and is no longer available. Could you re upload some pics? Thanks archive.org https://web.archive.org/web/20110430025055/http://members.cox.net/chipsbyal/page/project/280z/index.htm Quote Link to comment Share on other sites More sharing options...
yiannit280z Posted June 19, 2020 Share Posted June 19, 2020 On 6/9/2020 at 11:25 AM, ZHoob2004 said: archive.org https://web.archive.org/web/20110430025055/http://members.cox.net/chipsbyal/page/project/280z/index.htm Thats a big help! Thanks Quote Link to comment Share on other sites More sharing options...
