Z1NONLY Posted August 15, 2008 Share Posted August 15, 2008 just got a 78 280z last friday... been dreaming for one for years but the temp gauge ain't working.. need help where i should start the diag... also can't figure out which one is the temp sensor on the thermostat housing the left or right or bottom.. or is it somewhere else? i sure is a newby..to the z. any info appreciated.. jb Quote Link to comment Share on other sites More sharing options...
naviathan Posted August 15, 2008 Share Posted August 15, 2008 http://www.xenons30.com/reference.html I'm sure you can figure this one out. More than likely it's just a bad or disconnected sensor. Quote Link to comment Share on other sites More sharing options...
Z1NONLY Posted August 16, 2008 Author Share Posted August 16, 2008 thanks, for the site.. also got more help from the z-man of washington. thanks z-man. jb Quote Link to comment Share on other sites More sharing options...
Z1NONLY Posted August 19, 2008 Author Share Posted August 19, 2008 well, replaced the temp sender..the one with the male plug on the thermostat housing and did get the gage to work. but, when removing the sender i had to use a lot of elbow grease to get it out of the housing ... i drained the coolant just below the upper hose, but when i removed the thermostat a lot of coolant spilled over and on the intake manifold. cleaned it off. replace everything back. started the z and white smoke everywhere and i noticed a tapping sound around the thermostat housing or injector 1 or 2..tap tap tap louder than the rocker arms themselves. eventually the smoke when away but the tapping sound still there with a big loss of power..fixed a problem just to create a problem.. what an idiot.. before all that the z was running real nice and crispy. please help..what have i done? Quote Link to comment Share on other sites More sharing options...
Guest Michael-Silver-280zx Posted August 19, 2008 Share Posted August 19, 2008 Hi, I'm 18 and just got an old 82' 280zx and its got real trouble starting. I got it servised and whatnot but a mate told me the other day that he reckons it's a faulty temperature sensor. And as a result its not injecting properly to start or something... Does anybody have any ideas why my 280 only starts once every 15 goes? Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted August 19, 2008 Administrators Share Posted August 19, 2008 Michael-Silver-280zx said: Hi,I'm 18 and just got an old 82' 280zx and its got real trouble starting. I got it servised and whatnot but a mate told me the other day that he reckons it's a faulty temperature sensor. And as a result its not injecting properly to start or something... Does anybody have any ideas why my 280 only starts once every 15 goes? The temp sender for the gauge has nothing to do with the temp sensor for the EFI. They are completely unrelated/independant of each other. Thread moved to Troubleshooting, and retitled. Quote Link to comment Share on other sites More sharing options...
