zgeezer Posted January 1, 2002 Share Posted January 1, 2002 What gear ratios are available in the R230's? Any thing approaching 3.31, which I now have in the R200. I'd sure like to pull less than 2000rpm @75mph or thereabouts. zgeezer Quote Link to comment Share on other sites More sharing options...
Modern Motorsports Ltd Posted January 1, 2002 Share Posted January 1, 2002 Zgeezer, I don't know what gears are in an R230, a forum search would bring it out as it's been discussed many times. They're 3.54 or steeper (ie. higher numerical number) I'm 99.9995 sure. Your 3.36 R200 is quite rare and an enjoyable pieces in its own right. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 2, 2002 Share Posted January 2, 2002 The 3.36 R200s are standard in 74' 260z 2+2 with manual trans. Quote Link to comment Share on other sites More sharing options...
Modern Motorsports Ltd Posted January 3, 2002 Share Posted January 3, 2002 quote: Originally posted by rickeybell: The 3.36 R200s are standard in 74' 260z 2+2 with manual trans. Whereabouts? Not on Canadian builds or any US builds friends own. Only some very early 280ZX's have had them AFAIK. Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted January 3, 2002 Share Posted January 3, 2002 Ross, you have mail. Quote Link to comment Share on other sites More sharing options...
Mike Mileski Posted January 7, 2002 Share Posted January 7, 2002 I've got a note saved from an earlier search from this forum that the R230 from the twin turbo 300ZX (1990-1996) has a 3.61:1 ratio and the ones from normally aspirated ones have a 4.083:1 ratio, both viscous limited slip. Mike Mileski Tucson, AZ Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted January 7, 2002 Share Posted January 7, 2002 quote Quote The 3.36 R200s are standard in 74' 260z 2+2 with manual trans 4-spd manual to be exact, which makes it even rarer. The Z32 TTs have a 3.69:1 final drive. Quote Link to comment Share on other sites More sharing options...
Ray Posted January 7, 2002 Share Posted January 7, 2002 If you get a r230 out of a Q45 it has a 3.54 in it ... depending on which trans you are running this is a very popular gear.... the 4.08 in such a light car would be overkill with a V8.... Quote Link to comment Share on other sites More sharing options...
Mikelly Posted January 8, 2002 Share Posted January 8, 2002 Ray, it really depends on which trans you use...I'm actually searching for a 4:10 gear ratio because my T56 in my current configuration (383 Stroker w/ hydraulic roller 535/550 Lift - 284/292 dur. Advertised) won't allow my motor to function optimally at RPMs below 2000 in 6th gear... The cam isn't working below that and 6th gear at 2000RPMs is pulling something in the range of 105mph! Mike Quote Link to comment Share on other sites More sharing options...
