flexible SS lines at master??
Im thinking of adding a short flexible line off at the master cylinder in order to make it easier to install my proportioning valve (PV). Is this OK? Is there something I should be careful of?
Im adding a Wilwood PV...my plan is to make a braket that attaches the PV to another brake hard line. I will be a small aluminum block with a groove in it that will go over the brake line. There will be two threaded holes in the block in line with the two mounting holes on the PV. I plan to bolt these together over the hard line and the flexible line will allow easier fit.
OK???
