Cylinder head spacer?
cygnusx1
The picture looks like a headgasket. The description doesn't say what the thickness of it is, unless I missed it. As far as I can see it would have all the same drawbacks of a thicker headgasket. Shimming the cam towers would be my preferred method of fixing the timing chain slack and cam timing issues.
  • 2 months later...
Any additional comments on its application? Would you need a head gasket below and above for proper sealing (Head-gasket-shim-gasket-block)? I'm trying to get 2.5 to 3.0 mm between my head and block for my stroker rebuild (L28 rod and zxt dish pistons).
This will be for a turbo application, so I'm not too concern with quench.
