kiwi303 Posted September 9, 2008 Share Posted September 9, 2008 I brought the gearbox that came with my RHD 280Z fairlady (280ZX stateside) back to the workshop from the car in the shed at the far end of the farm, however looking at it the starter motor bulge in the belhousing has obviously been welded in rather than cast in place. It's now in a 4 o'clock position on the front of the bellhousing, placing it on the passenger side of the car, (driver side in the states). That called for a bit of looking around since I was sure that the stock position was on the driver side (passenger side...) I found THIS: notice the starter on the right side of the motor... 9 o'clock position. I'll take some photos and load them up, but does anyone know what my tranny, which looks identical to a FS5W71B, has been modified to fit? Quote Link to comment Share on other sites More sharing options...
NZeder Posted September 9, 2008 Share Posted September 9, 2008 Maybe I have seen one other box setup like this here in NZ too. It was for a 351 V8 conversion using an adaptor plate between the Ford V8 and the datsun box. Or it might be a different box ie FJ20 (not sure never seen an FJ20 box before....maybe a search of trademe will show a pic). The FJ20 box was often used here in NZ for 240z/260z race cars back in the day as they were later model (ie almost the last of the B boxes) and depending on the car the box came from sometimes had good ratios. However most just swap on the L6 bellhousing onto the FJ20 box. Quote Link to comment Share on other sites More sharing options...
Trevor Posted September 9, 2008 Share Posted September 9, 2008 How about an MGB? Whatever this lad is holding - this starter is on the left side: Quote Link to comment Share on other sites More sharing options...
Tony D Posted September 9, 2008 Share Posted September 9, 2008 LOL! "Atlas Shrugs!" I would do that to transport A12 and A15 Engine/Trans assemblies. Having a small engine does have advantages! My wife would freak when she saw me do that. LOL No help, but it's funny, I couldn't resist! Quote Link to comment Share on other sites More sharing options...
kiwi303 Posted September 10, 2008 Author Share Posted September 10, 2008 Maybe I have seen one other box setup like this here in NZ too. It was for a 351 V8 conversion using an adaptor plate between the Ford V8 and the datsun box. Umm... that might be it... I got the box, definately a FS5W71B from all the pics on the net and HybridZ, but the car as posted on Zclub, is set up with a Twin pipe V8 layout with connector tube between the two pipes just back of the tranny/driveshaft join point. The car also came with a number of 302 SBF pistons and a BIG air cleaner casing with a "4 barrel" decal in it. So the previous owner may have been planning to use the fairlady box on his 302 conversion. I'll have some pics later today. Quote Link to comment Share on other sites More sharing options...
Careless Posted September 10, 2008 Share Posted September 10, 2008 that doesn't even look like he's holding it well enough to support it. And even so, I would never have it that close, on my back, with a glossy oil pan near a good condition car of any sort. 300 lbs crashing 6 feet to a car is like driving into people jumping off the Dufferin bridge. And did I forget to mention that there is an obvious Photoshop on the sign just above the bell housing too? Atlas didn't use come-alongs and chains tied to roof trusses and digital technology to make it look like he actually did work. lol Quote Link to comment Share on other sites More sharing options...
kiwi303 Posted September 10, 2008 Author Share Posted September 10, 2008 Heres the pics of my gearbox... you can clearly see where the starter bump has been shifted over to the other side. A bottom view Heres a pic from trademe, the NZ equivalent of ebay, showing a FS5W71B without any modifications... quite a lot cleaner The guy selling this is a member of Zclub.co.nz Quote Link to comment Share on other sites More sharing options...
NZeder Posted September 10, 2008 Share Posted September 10, 2008 Yep a cut and shut for a installation behind a different engine and I would guess a v8 install. Quote Link to comment Share on other sites More sharing options...
kiwi303 Posted September 10, 2008 Author Share Posted September 10, 2008 So, if it's now a V8 G-box, and I get an adapter plate, how hot a 302 can I run before having to shop for a new box? In all the reading I've done here on Hybrids, I haven't run across a post or thread that give the typical breaking strains of the various boxes... Sure theres statements than such-and-such a box is stronger than that one over there, and others talking about swapping out their boxes as they upgrade. But theres nothing that says that a FS5W71B with break at x HP and y Ft/Lb, and a FS5W71C will break at x+A Hp and y+B Ft/Lb I gather from discussions on blown trannys, taken with other posts about their engine upgrades that the FS5W71B box will manage 250Hp, but break between that point and 300Hp when driven in an exciting manner. Can anyone give a hard figure of the Do-Not-Exceed HP for a FS5W71B box to keep engine tunes under? Quote Link to comment Share on other sites More sharing options...
Careless Posted September 10, 2008 Share Posted September 10, 2008 71C's are putting down more than 400+ rwhp behind SR20's. If you feel like it's gonna be a burden soon, get an FS5R30A from an 05/87+ Z31 churbo! Quote Link to comment Share on other sites More sharing options...
NZeder Posted September 10, 2008 Share Posted September 10, 2008 71C's are putting down more than 400+ rwhp behind SR20's. If you feel like it's gonna be a burden soon, get an FS5R30A from an 05/87+ Z31 churbo! Z31 are hard to find in this part of the world and ones wth a FS5R30A even harder. Quote Link to comment Share on other sites More sharing options...
