MaTTSuN Posted September 14, 2008 Share Posted September 14, 2008 thats the sound my engine makes when i start up it cranks then something hits really hard and it barley cranks then it starts its like all the power from the starter goes somewhere else like the ignition maybe. but it is very anoying and it makes my cool turbo Z sound like a crappy car on start up just wondering how i can tune it out Quote Link to comment Share on other sites More sharing options...
Noddle Posted September 15, 2008 Share Posted September 15, 2008 thats the sound my engine makes when i start upit cranks then something hits really hard and it barley cranks then it starts its like all the power from the starter goes somewhere else like the ignition maybe. but it is very anoying and it makes my cool turbo Z sound like a crappy car on start up just wondering how i can tune it out Timing to far advanced ? what's your timing set to at idle ? Nigel Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted September 15, 2008 Share Posted September 15, 2008 More importantly, what's it set to during cranking? 10 degrees should work well. Idle would be 20-24 degrees. Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted September 15, 2008 Share Posted September 15, 2008 Are you using my map? My car used to do the exact same thing. It went away when I switched to EDIS. I even tried reducing the timing at cranking speeds and cranking- Kpa values but I never fully fixed it. Quote Link to comment Share on other sites More sharing options...
MaTTSuN Posted September 16, 2008 Author Share Posted September 16, 2008 ive made my own map ... i started with metro's then tuned from there. Id like to go to EDIS but maybe not till next summer, need to start collecting the parts Quote Link to comment Share on other sites More sharing options...
mobythevan Posted September 17, 2008 Share Posted September 17, 2008 If you are using time based cranking you may need to hold ignition off for a couple spins of the crank so that it gets up to speed before you start firing. Quote Link to comment Share on other sites More sharing options...
WizardBlack Posted September 20, 2008 Share Posted September 20, 2008 Too much cranking timing can virtually backspin the motor. Quote Link to comment Share on other sites More sharing options...
