Changing the transmission fluid in a 240z
I've found it easiest to refill from above via the engine compartment. Get 2 feet of ~ 1/2" clear tubing at Lowes/HD. From under the car insert one end of the hose into the fill hole on the tranny and route the other up towards the battery. Then just put the nipple of oil container (I'm assuming you're using a 1 quart bottle) into the hose and squeeze. If it's cold you may want to soak the bottle in warm water beforehand to make it flow better.
It's easier and neater than doing it from under the car.
Heh, I did it this morning that same way before even reading your post. Except I didn't warm the oil first, I poked a hole in the back of the bottle and used the air compressor to give it some pressure. Thanks!
Yes, but make sure you can remove the fill plug before you drain the oil. Often those plugs are over-tightened and it's a bear to get them out. Unlike the tranny which can be filled via the shifter if necessary, there's no other practical way to fill the diff while it's in the car.
