badgti Posted September 18, 2008 Share Posted September 18, 2008 guys, got a small queastion on the r32 rb26dett.i am planning on getting one in my 240z but been through many posts regarding oil pump problems and seen tht many have opted to change the oil pump collars a r33 crank and a better oil pump.can i just go for a complete r33 block, doess the r33 block bolt up to the r32 rb26 head?sorry for the nob question but am really new to rb's.reason why i want to get a complete r33 block is so that i can rebuild the block and yet still have the r32 one as a spare. Quote Link to comment Share on other sites More sharing options...
Wedge Posted September 18, 2008 Share Posted September 18, 2008 yes it fits but the best way and cheap way is to get the crank collar problem fixed . I dont remeber how its done but its the cheapest way to fix this problem . Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted September 18, 2008 Share Posted September 18, 2008 There is a member here on this board selling crank collars to address the short oil pump drive on the early r32 rb26dett motor. He is selling a rear head drain fitting also, that allows the oil to return to the pan more efficiently. Quote Link to comment Share on other sites More sharing options...
badgti Posted September 18, 2008 Author Share Posted September 18, 2008 correct me if i'm wrong but by getting the crank collar done would this be better than a r33 crank or is the result equally the same? Quote Link to comment Share on other sites More sharing options...
Careless Posted September 18, 2008 Share Posted September 18, 2008 same. especially since you have your crank out, you should check your run-out at the machine shop. once you heat up the snout and press on or weld on the collar, your crank is susceptable to a slight out-of-round. It's not a huge issue. Procuring an R33 crank would be the same cost or more than the collar + installation and blue-printing of the unit once it's said and done. And you can never be sure that the R33 crank will be in the same condition. And plus, you can bargain with the machinist and tell him to do some oil hole cleaning and chamfering as part of the collar + post inspection price. I guess some may find R33 cranks in top condition for less, but then again... not everyone can. Quote Link to comment Share on other sites More sharing options...
stony Posted September 21, 2008 Share Posted September 21, 2008 If you have the crank out and rebuilding the motor get a r33 crank (New) it will make the rebuild process much easier. Quote Link to comment Share on other sites More sharing options...
