sorealsosurreal Posted October 16, 2008 Author Share Posted October 16, 2008 thanks for the imput guys i guess NA stroker it is Quote Link to comment Share on other sites More sharing options...
mikedc528 Posted October 17, 2008 Share Posted October 17, 2008 http://www.amsperformance.com/store/product_info.php?products_id=152 Check out that link...their dished pistons are supposed to give a lower comp. for turbo applications. http://www.zccjdm.com/catalog.php/azcarbum/dt43033/pd858312/KAMEARI_L6_METAL_HEAD_GASKETS And with Kameari's 3mm head gasket should give a lower CR. I didn't even know they made 3mm head gaskets till I went on their website. Quote Link to comment Share on other sites More sharing options...
sorealsosurreal Posted October 23, 2008 Author Share Posted October 23, 2008 question. where are the balancing pads on the 9mm 240z rods. there isnt really any noticable balancing pad on them like there is on a chevy rod. anyone help me out? Quote Link to comment Share on other sites More sharing options...
RisingSun Posted October 25, 2008 Share Posted October 25, 2008 I know this is late in the game, I was searching for something else and came upon this post. In regards to your research of a gasket, I had trouble finding one to suit my stroker project, and when I was building it I hadn't seen or heard of the Kameari product line yet. The only one I could find was the Nismo gasket, but it was too thick and would have effected the CR for my build. The problem for me was to find a gasket that allowed the overbore for my 3.1 AND cover the positive deck height that the 240 rods created with the pistons. The head had been milled slightly to make a good gasket surface (along with the block) so it also changed slightly the overall volume, and I was left with a deck height of -.020. I even contacted Cometic Gasket but they talked me out of paying them for custom gaskets after I had already shipped them the Nismo for a template because they can only make solid copper gaskets, which for a street car they told me would not last. It had something to do with the constant heating and cooling cycles over time would eventually cause it to leak, versus a race engine that would probably change their gaskets routinely. At least they were good honest guys there, they could have just done what I asked and let me deal with the problems down the road. What I ended up doing was buying the Nismo gasket and took out a layer to make it a little thinner so it ended up to be almost .060. I wish Kameari offered those nice cusomizable gaskets when I was losing sleep over this. I have the Data Sheet I can post or email to you, but I will have to try to scan it onto the computer first. I can do that tomorrow if you are interested. The specs are all in inches but you can convert it easily. Basically, I have the N42 block, P90 head, flat top pistons (ceramic coated), which the spec sheet spit out a 10.461:1 static compression ratio after all the measurments were made. Fooling with the gasket thickness is a nice way to manipulate the CR when all your other parts have been purchased. Quote Link to comment Share on other sites More sharing options...
sorealsosurreal Posted October 25, 2008 Author Share Posted October 25, 2008 haha thanks its still very good info i havnt oredered pistons yet so i also havnt ordered a head gasket. i was wondering about taking layers out of the metal gasket but figure it wouldnt give a seal but thats very good to know. much appreciated Quote Link to comment Share on other sites More sharing options...
