itsaprothing Posted November 5, 2008 Share Posted November 5, 2008 I won a 5 speed M/T ECU from a seller on ebay who also had a listing for the A/T version for the 1g-gte and they accidentally switched the orders and sent me the ECU labeled A/T. I emailed them for an exchange and they claim that they knew it said A/T on it but it came out of a 1990 Supra 5 speed and it will work with my engine and trans. I emailed back saying that I don't want to take risks and that I just want what they advertised and I should get what they listed and pictured. They promised an exchange but it's been 4 days and so far they are MIA, and it's looking like i'm stuck with the A/T ECU. I've been looking around doing searches on google and some are saying that the ECU could really care less if my transmission is there or not and that the A/T will work but will put out less HP and run richer. Some are even saying that running an A/T ECU in a M/T car is illegal. There are so many things said about the matter and I really just need to know.. Will the A/T ECU work fine with the 5 speed? any help is greatly appreciated. Quote Link to comment Share on other sites More sharing options...
240zwannabe Posted November 5, 2008 Share Posted November 5, 2008 I'm like you, I wouldn't take the risk. I would first, threaten the seller that you are going to report them, then if they don't reply, report them! Any reputable seller on ebay doesn't want any kind of negative feedback, so hopefully that will yield your requests. Quote Link to comment Share on other sites More sharing options...
RUSSJZ-ZED Posted November 5, 2008 Share Posted November 5, 2008 quite a few people on this forum http://www.toymods.net/forums/ have used this engine, someone should be able to tell you if it's compatible. (search first) Quote Link to comment Share on other sites More sharing options...
itsaprothing Posted November 6, 2008 Author Share Posted November 6, 2008 thanks russjz but it's $50 to join toymods and i'm pretty sure a thread would show if they had an answer from all the google searches i've done. I am a member of club4ag and toyota3tc, and sasupras and yet still nobody has an answer. anybody running a 5 speed on any engine with an A/T ecu? Quote Link to comment Share on other sites More sharing options...
RUSSJZ-ZED Posted November 6, 2008 Share Posted November 6, 2008 thanks russjz but it's $50 to join toymods and i'm pretty sure a thread would show if they had an answer from all the google searches i've done. I am a member of club4ag and toyota3tc, and sasupras and yet still nobody has an answer. anybody running a 5 speed on any engine with an A/T ecu? I'm running 1J Vvt auto ECU with R154, no problems,all you have to do is over ride neutral start switch,and hook up speedo(cable or electronic??)and reverse switch, if you are lucky ,toyota may have used same plug on 1G-GTE as they did on the 1J .pic's of my plug modification on link to pic's below. Only an expert will be able to tell the difference between an Auto and manual ECU, just remove the sticker that says its an auto. I think you only have to pay $50 to be a financial member of Toymods, signing on and using forums is free (used to be, that's Australian dollars anyway, current exchange rate is 50 dollars Australian = 2 flat rocks) Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted November 7, 2008 Share Posted November 7, 2008 What's the oem number on the ecu? Quote Link to comment Share on other sites More sharing options...
Overkill Z Posted January 23, 2009 Share Posted January 23, 2009 im running a 2jz gte with a auto ecu...the JDM importer said it doesnt make a differance...but i will be starting the motor for the first time in the next couple weeks. Ill let you know. Im running a r154 as well. Quote Link to comment Share on other sites More sharing options...
turborized Posted January 24, 2009 Share Posted January 24, 2009 I've used A/T ecu's on a few M/T motor before, not a 1jz or 2jz, and it works fine. However check engine turns on cause it's not reading the A/T. I don't know if it runs richer or not for I've never saw the need to. Quote Link to comment Share on other sites More sharing options...
Guest palugi2602jz Posted March 13, 2009 Share Posted March 13, 2009 Hey mike (zgad) What did you have to do about the cooling system, what radiator are you running? Thanks Chris Quote Link to comment Share on other sites More sharing options...
ShaggyZ Posted March 13, 2009 Share Posted March 13, 2009 Hey mike (zgad) What did you have to do about the cooling system, what radiator are you running? Thanks Chris Clearly you're new to forums. Please either go searching for that info or PM him directly instead of threadjacking. Quote Link to comment Share on other sites More sharing options...
