L24e fuel rail
Irishdog810
  Irishdog810 said:
Are there any places that will make a custom fuel rail for the L24e straight six engines? Going in my 810 hardtop thanks to all in advance for the info.
Since you added the "E" to the L24 I'm wondering if you're trying to say it's fuel injected, and not carb'd?
If it's fuel injected, I would assume it's using an L28 intake, and then you could just give ol' Pallnet's site a look see. He can make you an EFI rail for the L28 based on what style of injector you want to use.
If it is indeed carb'd, which is what I'm guessing is the case... then an aftermarket rail will not be as easy to find.
I actually do have an aftermarket rail for the dual SU's believe it or not. I bought it used for $20. I was told that it was made by Pallnet a couple of years back, but I dont know if he is still making them, and it was using an alluminum stock that, according to his site, he no longer uses.
Either way, I'd check out Pallnet's site, and/or shoot him a PM.
