Replacement Turbo Manifold studs
Noddle
Hi,
I'm looking for 1/2 inch longer exhaust studs (because of the 1/2 inch spacer between manifold and turbo), with the same coarse / fine thread that the original studs have,
does anyone know where I can buy these, preferable from a online vendor
Thanks
Nigel
You can probably get the (automotive) studs at a local automotive or hardware store, no need to kill yourself on international shipping...
The size is M10x1.5 and the stock ones are a little over 1.5 inches long. 1/2 inch longer would be about 50mm
Here is an example: http://www.pronto.com/M10-X-1.5-X-p_1117925661-PP
Although for the stock stud, the threaded portion that goes into the manifold is a little over 1/2 inch. You may need to bore out the holes in the spacer a little to account for the non-threaded portion (at least that is what I ended up doing).
hope this helped...
  • 1 month later...
