AkumaNoZeta Posted December 3, 2008 Share Posted December 3, 2008 I found this article on making a SR20DET head handle 9000 RPM http://www.nicoclub.com/articles.php?id=238409 but I couldn't find any articles on how to make the bottom end handle it. Could the stock bottome end handle the revs with stock-20psi? Since I'm here anyways I might as well ask because I've been trying to find an answer for this too, how many pounds of boost can you run on a properly tuned engine for 91 octane without the meth injection? Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted December 3, 2008 Share Posted December 3, 2008 Contact http://www.mazworx.com/ Mark has a nasty S15 9000rpm 1600HP SR22VE-T. SR20's are there specialty. Quote Link to comment Share on other sites More sharing options...
73DatsunZ Posted December 3, 2008 Share Posted December 3, 2008 Thats a good writeup on the nico club Quote Link to comment Share on other sites More sharing options...
240z!!! Posted December 4, 2008 Share Posted December 4, 2008 I found this article on making a SR20DET head handle 9000 RPM http://www.nicoclub.com/articles.php?id=238409 but I couldn't find any articles on how to make the bottom end handle it. Could the stock bottome end handle the revs with stock-20psi? Since I'm here anyways I might as well ask because I've been trying to find an answer for this too, how many pounds of boost can you run on a properly tuned engine for 91 octane without the meth injection? its not the stock bottom end to be worried about its the t25 unless you have a newer sr with the t28....safely id say 12 lbs...you could probably get more but its not sertain it wont blow Quote Link to comment Share on other sites More sharing options...
AkumaNoZeta Posted December 4, 2008 Author Share Posted December 4, 2008 What about a GT35 or a GT40, would those be good for such an engine? Quote Link to comment Share on other sites More sharing options...
SR240Z Posted December 4, 2008 Share Posted December 4, 2008 We are running the GT3076R and peak power is right at our redline at 7800rpm and are still running the hydraulic head but with Tomei Cams and rocker arm stoppers. If we could rev to 9000rpm we would potentially see more power and at 26psi. I think a GT35 would work pretty well if you have the other supporting mods and are reving to 9k as well. Quote Link to comment Share on other sites More sharing options...
ReefsRocket Posted December 6, 2008 Share Posted December 6, 2008 Has anyone seen the castrol topshop contest? Long story short... Some shop building a sr20det redtop said they can build sr's to 11,000 redline he was insisting on cp pistons,high duration cams,solid lifters,ect.But for the bottom end besides cp pistons it was xbeam rods,sleeved,bored to 90 i believe. IDK if that helps at all. Quote Link to comment Share on other sites More sharing options...
AkumaNoZeta Posted December 6, 2008 Author Share Posted December 6, 2008 What are cp pistons? I've never heard of X-beam rods either. I-beam, H-beam, but never X-beam. Quote Link to comment Share on other sites More sharing options...
majik16106 Posted December 6, 2008 Share Posted December 6, 2008 cp is a brand. and for x beam.. pauter says this is an x beam.. http://www.maperformance.com/pauter-machine-x-beam-4340-connecting-rods.html?iorb=4764&utm_source=Yahoo&utm_medium=SSP&utm_campaign=BROI Quote Link to comment Share on other sites More sharing options...
ReefsRocket Posted December 6, 2008 Share Posted December 6, 2008 Yeah ^ thats they brand they were useing,Just check out the videos they are short and almost annoying but cool to see. syntectopshop.com Quote Link to comment Share on other sites More sharing options...
fast-datsun Posted December 24, 2008 Share Posted December 24, 2008 SR20DET hyd lifter has been the limit of rpm, not the bottom end, solid lifter help get to 9K but the VVL conversion easily pass that.... Quote Link to comment Share on other sites More sharing options...
Prok0 Posted December 26, 2008 Share Posted December 26, 2008 Yep, rockers tend not to like 9k rpm. Solids will help, but like the poster above me stated, a VE head pretty much solves the problem. Its not too difficult to do the VE head on a rwd motor either.. If you want to do it cheap and easy you can run a 20v CAS, VE lower intake runners with a custom plenum, DET exhaust manifold, some lines to remote mount the solenoids, and you can run a greddy mss or v-afc or some sort of controller to do cam switch, and just get a rom tune. Oh and you would also have to run S15 coilpacks, some thin denso units, or just run stock SR's to the side with little jumper wires possibly. And the bottom ends are good to 500+ whp stock, and pretty high revs as well, although you start to see wrist pin deflection around 450whp Quote Link to comment Share on other sites More sharing options...
True School 240Z Posted December 26, 2008 Share Posted December 26, 2008 wow. Quote Link to comment Share on other sites More sharing options...
