temp sending unit adapter
My old engine used that adapter if thats what you're taking about. No issues, gauge worked fine. In fact I used one in the thermo housing for the gauge and there was a fitting in the water pump I used to run my fan. BTW if you live in Suwanee you live about 4 miles away. Let me know if you need a hand with anything.
Dale
has anyone done the modification described in Mike Knell's book in order to use the 280Z temp sending unit in a chevy engine? any tricks I need to be aware of, did it work sucessfully? thanks for any info, and have a great holiday season!
i have also done the swap. I added an adaptor and mounted auto meter gauges in the firewall above the master cylinder.I have oil pressure vacuum and temp there with a toggle switch for back lighting.I have pics of it ,email me if you want to see them. I used 2 AND 1 ,16TH GAUGES and used a 2 ,1 8th key hole saw .also mounted 6al msd box and coil behind master cylinder. by the way for those of you with stick cars, tilton has a new master cylinder that is shorter( yes he said shorter) than the factory one so you do not have to relocated washer bottle,B
