'Comp' 5-speed value?
heavy85
I've got two 'comp' 5 speeds taking up space in my garage. When I bought the car one was listed as '$1500 competition transmission' and the other I picked up locally. These are both overdrive with std shift pattern but with the steel synchros so they are not the more desirable dogleg shift pattern non-overdrive. One's in decent shape the other needs at least two synchros replaced. Any idea what these would be worth and where would be the best place to try to sell them?
Thanks
Cameron
The FS5C71B overdrive "race" transmission was available as a close ratio (32010-N3130) and wide ratio (32010-N3030). These units are generally not worth as much as the F5C71B direct drive drive "Option" boxes.
It would help to know which transmission you have. Gearing is as follows:
Close - 2.906, 1.902, 1.308, 1.00, .864
Wide - 3.321, 2.077, 1.308, 1.00, .864
  • 1 year later...
