R200 Swap Problems
Guest buschj
You may have to use an R200 rubber mount from a 75-78 car as well. That I don't remember on mine as to which I used. My r200 was from a 78 and my car a 72. All I changed was mustache bar and diff and MAYBE the front mount, I just can't recall. It probably wouldn't hurt to have a new one however...
Guest buschj
Thanks for the lightning fast responses; your help is greatly appreciated. I looked everywhere and couldn’t find any mention of putting the loops in front. You guys are awesome.
Guest buschj
Problem:
The front differential mount and the frame mounting area DO NOT line up when the mustache bar is correctly mounted. The front mount is 1-½ inches in front of where it needs to be for the holes to line up. The only way I can see it working is to turn the mustache bar around, but it looks like it could interfere with the link mounting braces.
Here is a list of the parts I’m using:
Differential - 81’ 280ZX 3.9
Mustache bar - 78’ 280Z w/R200 w/ urethane bushings
Front Mount – Original
Car – 73’ 240
HELP!!!!!!!!!!!!!!!
