mark.deady Posted December 30, 2008 Share Posted December 30, 2008 looking to see if an air induction valve case del is possible, i have a l28 280zx. when i get her running the motor is really loud but only because of the secondary air valve... was wondering if it is possible to just delete it of am i stuck... thanks mark Quote Link to comment Share on other sites More sharing options...
nismopick Posted December 30, 2008 Share Posted December 30, 2008 That was one hard post to understand. Maybe try spell check next time? Are you talking about the auxiliary air regulator? Quote Link to comment Share on other sites More sharing options...
woldson Posted December 30, 2008 Share Posted December 30, 2008 Loud?! Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted December 30, 2008 Administrators Share Posted December 30, 2008 ... secondary air valve... Mark, Not sure what "part" you are referring to with the description of "Secondary Air Valve". My EFI terminology is getting rusty The only air valves I am aware of on the N/A L-28 are; 1) Air Flow regulator, (allows for increased idle speed when started cold). 2) Throttle Valve, (self explanatory). 3) BCDD, attached to the bottom of the throttle body on early cars, bottom of intake manifold on later cars, used for emissions purposes during deceleration 4) Idle speed control valve. Early cars this was cast integral on top of the throttle valve, later cars was remote mounted, bolted to the side of the intake manifold, used to adjust warm engine idle speed. 5) EGR Valve, (self explanatory). 6) ???? Quote Link to comment Share on other sites More sharing options...
mark.deady Posted December 30, 2008 Author Share Posted December 30, 2008 my manual calls it "The air induction valve case" located under the ignition coil i can hear the the sound of the moter through it... if i put my fingers over the hole and it quiets it down a lot... i had a similar set up on my trans am it was some type of air pump for when it was cold out... part of the emissions stuff... thanks mark Quote Link to comment Share on other sites More sharing options...
Niku-Sama Posted December 30, 2008 Share Posted December 30, 2008 what manual calls it the air induction valve case? hayes, chiltons or factory service? Quote Link to comment Share on other sites More sharing options...
mark.deady Posted December 30, 2008 Author Share Posted December 30, 2008 hayes Quote Link to comment Share on other sites More sharing options...
nismopick Posted December 31, 2008 Share Posted December 31, 2008 Ah yes... because your car is an 80 Federal (page 50 in Haynes). Yes, you should be able to remove it as long as you cap all hoses & lines. Quote Link to comment Share on other sites More sharing options...
