Should a NA 280zx engine sound like this?
RaGnaR_RattmuFF
Sounds like an exhaust gasket leak.
Seems to be louder on the drivers side (exhaust side), than the passenger side. Also gets louder when the throttle is cracked open. Very characteristic of an exhaust leak at the head.
Try getting a large screwdriver, sticking the handle end against your ear and (carefully) set the tip against the base of each injector as it is running. Then do the same over on the passenger side of the head, near where the valve rockers are. Listen for the tapping to get louder.
If that doesn't turn anything up, get a length of tubing about a meter long and stick one end in your ear.. fish the other end around the intake and exhaust flange listening for a leak.
Stethoscope.. two versions, one solid, for mechanical ticking detection, one air-based, for vacuum/pressure leaks. both types also work to "listen" for flow inside hosing... If you can pick up the "sound."
