luvmy280zxt Posted January 5, 2009 Share Posted January 5, 2009 :cry2:I searched for this but didnt find out the exact answer. Im sure some out here knows for sure. Is the transmission from a 79 n/a different from an 82 turbo? I used a 79 manual on my 81 turbo so thats y i was wondering? Thanx P.S. If someone does a search and finds the answer, plz let me know. Id like to read it. Quote Link to comment Share on other sites More sharing options...
Edz280zx Posted January 5, 2009 Share Posted January 5, 2009 Simple answer, yes, they are different. The 79 n/a has a nissan tranny, and the 82 turbo has a Borg Warner t-5. Quote Link to comment Share on other sites More sharing options...
Niku-Sama Posted January 5, 2009 Share Posted January 5, 2009 your gears are really short arent they? Quote Link to comment Share on other sites More sharing options...
naviathan Posted January 5, 2009 Share Posted January 5, 2009 Interesting that you were able to use just the transmission. I would have expected you would have changed out the driveshaft, rear diff (or at the minimum the pinion flange) and trans crossmember. The differences are pretty extreme as far as Z transmissions go. The T5 has shorter gears requiring a taller rear diff of 3.54:1. The standard 79 trans had taller gears which required the use of a shorter rear of 3.90:1 (79 actually had several rear diff ratios and I'm still confused as to what the most common is). So the combo of the 79 trans with a turbo diff would give you a very long gear set meaning slow launches, but lots of top end. Also your speedo is going to be way off so don't use that to judge. Quote Link to comment Share on other sites More sharing options...
roger.svoboda Posted January 5, 2009 Share Posted January 5, 2009 did the exact same thing 81 tranny into 81 turbo. as naviathan says turbo drive shaft that fit the auto tranny didn't work with 5speed. come to Jan meet in Redmond I'll tell you all about it. Roger Quote Link to comment Share on other sites More sharing options...
RivJunkie646871 Posted January 5, 2009 Share Posted January 5, 2009 I blew a hole in the rear of my 83 n/a 5 speed trans years ago. So in a pinch i swapped in a 4 speed I had that was in a 260. It was a direct bolt in. Hated the RPM's in 4th. I wasn't aware of any differences. Interesting. Quote Link to comment Share on other sites More sharing options...
xenonxiii Posted January 5, 2009 Share Posted January 5, 2009 http://xenons130.com/Transmissions.html Quote Link to comment Share on other sites More sharing options...
naviathan Posted January 5, 2009 Share Posted January 5, 2009 I blew a hole in the rear of my 83 n/a 5 speed trans years ago. So in a pinch i swapped in a 4 speed I had that was in a 260. It was a direct bolt in. Hated the RPM's in 4th. I wasn't aware of any differences. Interesting. The differences in the 4 and 5 speeds would be minimal. It's the difference in the standard 5 speed and the T5 5 speed. Quote Link to comment Share on other sites More sharing options...
RivJunkie646871 Posted January 5, 2009 Share Posted January 5, 2009 The differences in the 4 and 5 speeds would be minimal. It's the difference in the standard 5 speed and the T5 5 speed. Oh, ok. Just the turbo cars had the T-5. I should read first! Quote Link to comment Share on other sites More sharing options...
luvmy280zxt Posted January 6, 2009 Author Share Posted January 6, 2009 Well this being my 1st Z I didnt know that the n/a stuff would not all match the 81 turbo stuff. Well actually just the drive shaft. I had a transmission shop look one up for me cuz by that point I was pissed that i could finish up and drive the dam thing...LOL:tongue:. It is slow off the line but top end is good. I kept the rear diff in on the 81 turbo, I have the 79 n/a diff sitting in my garage. So from what i gather...it would be better to have the 5 speed from an 82 0r 83 turbo vice the 79 n/a? Oh ya.....I got lucky this week and im getting another 81 turbo. Black and gold!!! 500 $ Runs good just needs sum tlc!! Now i have a white and black one! LOL EBONY AND IVORY!! Quote Link to comment Share on other sites More sharing options...
