Crank difference
bianski
  • 3 weeks later...
Curious, my 225mm clutch has held up fine in turbo service.
It all depends on what you are doing, and what clutch material you use.
It's not a 'mandatory' item by any means.
The argument can be made that the increased moment of inertia of the 240mm Pressure Plate kills a lot of throttle response in small throttle transients.
My wife hates my turbo car, because she says it has an 'on-off throttle'...
Muahahahahaha!
if they are the same then why fidanza make 2 different aluminum flywheels?
I think Tilton might have had two different flywheels, but I thought that my Fidanza was drilled for both, with a heat shield big enough to accomodate either the 225 or the 240
