kinknoppix Posted January 24, 2009 Share Posted January 24, 2009 I dont know what happened to this motor but if you can give me a sugjestion of what might be broken. Anything will help thanks. Quote Link to comment Share on other sites More sharing options...
ZXT_bean Posted January 24, 2009 Share Posted January 24, 2009 rod knock or possible piston slap? Quote Link to comment Share on other sites More sharing options...
ozconnection Posted January 24, 2009 Share Posted January 24, 2009 I just saw your vid on youtube. When did the noise start? Was the engine cold when you took that video? Do you punish your engine or do you drive it with some respect? Is power down? When was it last serviced? Have you done a compression/leakdown test? And this is like a crime scene. Gather as much information about your engine as you can and then tell us what you have found. Then we have a greater chance of figuring out your problem. Good luck mate. Quote Link to comment Share on other sites More sharing options...
srbigbutt Posted January 24, 2009 Share Posted January 24, 2009 Read this thread on classiczcars.com. I had that same sound and it turned out to be a lash pad had fallen off and the rocker arm was flapping around. http://www.classiczcars.com/forums/showthread.php?t=30832 I reinstalled the lash pad and did a valve adjustment and haven't had a problem since. Quote Link to comment Share on other sites More sharing options...
ShaggyZ Posted January 24, 2009 Share Posted January 24, 2009 srbigbutt said: Read this thread on classiczcars.com. I had that same sound and it turned out to be a lash pad had fallen off and the rocker arm was flapping around. http://www.classiczcars.com/forums/showthread.php?t=30832 I reinstalled the lash pad and did a valve adjustment and haven't had a problem since. Oooo... nice one. I think that's my vote, too. Get out a good sized screwdriver and use it as a stethoscope by sticking the pointed end against the valve cover and put your ear against the handle part and move the screwdriver to various points along the valve cover to find the loudest part. If it's really a dull sound no matter where you put it, try to get the screwdriver down to the block and do the same. NOTE: It is very important you don't stick the pointed end in your ear. If you can't figure out why, then do it and rid the world of you. Quote Link to comment Share on other sites More sharing options...
seabee280z Posted January 25, 2009 Share Posted January 25, 2009 bump Quote Link to comment Share on other sites More sharing options...
ShaggyZ Posted January 25, 2009 Share Posted January 25, 2009 seabee280z said: bump What the heck are you bumping this for? Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted January 25, 2009 Share Posted January 25, 2009 Sound should tell you if it is top end or bottom end. I'm on a blackberry so no youtube.......at least not easily. I use a timing light to determine which cylinder and knowing the top end spins half speed of the bottom end, you can usually divine what you know. Quote Link to comment Share on other sites More sharing options...
big-phil Posted January 25, 2009 Share Posted January 25, 2009 my money is on the lash pad. Pull that valve cover. Quote Link to comment Share on other sites More sharing options...
seabee280z Posted January 25, 2009 Share Posted January 25, 2009 why because iam having the same problem and awaiting the out come . does it bother you ShaggyZ said: What the heck are you bumping this for? Quote Link to comment Share on other sites More sharing options...
ShaggyZ Posted January 25, 2009 Share Posted January 25, 2009 seabee280z said: why because iam having the same problem and awaiting the out come . does it bother you Something more than "bump" would have indicated that. Quote Link to comment Share on other sites More sharing options...
kinknoppix Posted January 27, 2009 Author Share Posted January 27, 2009 Ill pull the cover off tonight after work but a cold front came in with rain.... Ill update and have a video up by tonight. Thanks yall Quote Link to comment Share on other sites More sharing options...
kinknoppix Posted January 28, 2009 Author Share Posted January 28, 2009 Quote Link to comment Share on other sites More sharing options...
jogaZ Posted January 29, 2009 Share Posted January 29, 2009 Pardon me people but i don,t see anything abnormal there. If some one can help me??????? Quote Link to comment Share on other sites More sharing options...
2eighTZ4me Posted January 29, 2009 Share Posted January 29, 2009 I'm with yogaZ - nothing visibly wrong there. Lash pads are all in their proper locations. Ewww...perhaps time to start looking at the bottom end of that motor...... Quote Link to comment Share on other sites More sharing options...
srbigbutt Posted January 29, 2009 Share Posted January 29, 2009 Same here. Pics look ok. How do they feel? Any of valve springs stuck down? Or are any rockers really loose? Could be a bent valve. Quote Link to comment Share on other sites More sharing options...
akangler Posted January 30, 2009 Share Posted January 30, 2009 Any oil in the engine? Oil pump? Quote Link to comment Share on other sites More sharing options...
big-phil Posted January 30, 2009 Share Posted January 30, 2009 did you start the motor with the valve cover off? That would tell you if its there or at the bottom. Quote Link to comment Share on other sites More sharing options...
ozconnection Posted January 30, 2009 Share Posted January 30, 2009 big-phil said: did you start the motor with the valve cover off? That would tell you if its there or at the bottom. You could start it, like Big Phil suggests, but try just cranking the engine. Start with the plugs in, then remove them and see if that changes the cranking sound/ valvetrain sound and you can watch the whole lot if someone turns the motor over for you. You will see if the oil pump is working too without spashing oil everywhere. Good luck. Quote Link to comment Share on other sites More sharing options...
shift00 Posted January 30, 2009 Share Posted January 30, 2009 Do a compression test man...then you'll narrow it down into a couple options. joe Quote Link to comment Share on other sites More sharing options...
