I left my gas cap on my ROOF!
S130Z
Not even the same model car had the same (fitting) gas caps. I have 2 280z and the gas caps are not interchangeable (unless you switch filler necks.) :P
My 77 had a key'd cap, but my 78 didn't and both are oem (labled nissan with part number)
Yea, there were different caps, with different filler necks. The later ZXs have a unique one that always gives the smog people heck because they can't test it or pressure test the fuel tank.
However there were only two or three keyways (different key blanks/cuts) that were used in the entire Datsun line, until the mid 80s.
S130Z, that's the exact gas cap I have, and it uses the older keyway, same as the 280Z. My ignition and door/hatch locks use a key with more wafers.
