rookie z Posted January 26, 2009 Share Posted January 26, 2009 i have a 98 ls1 i my 78280z .i am using the factory wiring harness.there is only 1 wire going to the connector on the alt,i cant get it to charge.what am i missing? Quote Link to comment Share on other sites More sharing options...
240zprace Posted January 26, 2009 Share Posted January 26, 2009 rookie z said: i have a 98 ls1 i my 78280z .i am using the factory wiring harness.there is only 1 wire going to the connector on the alt,i cant get it to charge.what am i missing? did you run a wire from +battery to the post in back of the alternator. Quote Link to comment Share on other sites More sharing options...
ColtGT4g63 Posted January 26, 2009 Share Posted January 26, 2009 If you have a hot wire going from the Alternator post, to the battery. And also have 12V at the wire in the plug with the engine running, and still have no charge, then you need to replace the alternator. That is providing that the alternator is grounded properly. Quote Link to comment Share on other sites More sharing options...
rookie z Posted January 27, 2009 Author Share Posted January 27, 2009 i have the wire from the back of alt going to the + side of the battery but i dont have power going to the 1 wire connector on top of the alt. Quote Link to comment Share on other sites More sharing options...
ColtGT4g63 Posted January 27, 2009 Share Posted January 27, 2009 What happens at that wire with the engine running? Quote Link to comment Share on other sites More sharing options...
rookie z Posted January 28, 2009 Author Share Posted January 28, 2009 i dont have power the connector.should i have power there or what? Quote Link to comment Share on other sites More sharing options...
ColtGT4g63 Posted January 28, 2009 Share Posted January 28, 2009 Yes, you should have power the connector. Quote Link to comment Share on other sites More sharing options...
rookie z Posted January 28, 2009 Author Share Posted January 28, 2009 should it be 12 volts?how about i splice a 12 volt wire into the connector .will that work? Quote Link to comment Share on other sites More sharing options...
lgoodson@pacbell.net Posted January 28, 2009 Share Posted January 28, 2009 I have been told by people that make harnesses that you need 12 volts to the " L" terminal on the alternator but you must put some resistance in line so as not short it out. This 12 volts will "excite" alternator and turn it on. Keep It clean guys. 350 OHM 1/2 watt resister is what I was told to use, Available at Radio Shack I believe. The 12v should be keyed Quote Link to comment Share on other sites More sharing options...
Phantom Posted January 29, 2009 Share Posted January 29, 2009 Try this thread here on the Hybridz website: http://forums.hybridz.org/showthread.php?p=881589 Quote Link to comment Share on other sites More sharing options...
rookie z Posted January 29, 2009 Author Share Posted January 29, 2009 i put the resistor in and it started charging , but by the time i went to check the voltage it stopped charging.i tried it 3 diffrent wires with the same results ,so do you guys think i should replace the alternator or rebuild it or what next? Quote Link to comment Share on other sites More sharing options...
